using V2 plus 4 Pro for waveguide
HV Systems 2023/04/24 16:32
Hello All
Can any one help us and guide as to how we can use nanoVNA QT and/or Saver
software for s parameter measurements of waveguide (WR284) component?
We have hired WR284 waveguide calibration kit with two waveguide to coaxial
adapters, two offsets shorts (1/8 & 3/8), and fixed Termination (load) for
SSLT calibration type. We have information on cut off frequency and lengths
of these offset shorts, however, there is no provision in software(s) to
utilize them for precise measurements.
Please guide and help.
Thank you
Sincerely
Vishal
Jim Lux 2023/04/24 07:09
On 4/24/23 4:02 AM, HV Systems wrote:
> Hello All
> Saver software for s parameter measurements of waveguide (WR284) component?
> coaxial adapters, two offsets shorts (1/8 & 3/8), and fixed Termination
> (load) for SSLT calibration type. We have information on cut off
> frequency and lengths of these offset shorts, however, there is no
> provision in software(s) to utilize them for precise measurements.
Your best bet is to calibrate the VNA at the coax connectors (with test
port cables). Do your measurements, and do the coax/WG conversion
calculations using some other software.
The NanoVNAs are sort of "coax 50 ohm" devices - that's what you get for
a $100 instrument.
However, if you want:
https://www.kirkbymicrowave.co.uk/Support/FAQ/How-do-I-perform-waveguide-calibration/
https://coppermountaintech.com/waveguide-calibration-of-copper-mountain-technologies-vnas/
both of these assume that the software supports entry of the WG Cal kit
parameters. The NanoVNA does not, I can't speak to NanoVNA2.
HV Systems Mail 2023/04/25 16:07
Thanks Jim.
Sent from [Outlook for Android](https://aka.ms/AAb9ysg)
**From:** NanoVNAV2@groups.io <NanoVNAV2@groups.io> on behalf of Jim Lux
<jimlux@earthlink.net>
**Sent:** Monday, 24 April 2023, 19:39
**To:** NanoVNAV2@groups.io <NanoVNAV2@groups.io>
**Subject:** Re: [nanovnav2] using V2 plus 4 Pro for waveguide
> Hello All
a $100 instrument.
calibration/
technologies-vnas/
