information request
viger3it 2020/10/22 12:33
Hi there,
few days ago I receive my Nano VNA V2 /S-A-A-2 and I try to connect it to a PC with Windows 10 OS. I download the software suggested but when I connect the USB cable nothing happen.
I can see that the pc detect the presence of new device but nothing else.
Can anybody help me about performing this connection step by step?
Many thanks
Giorgio
CT2FZI 2020/10/22 22:30
Hello
You need to install the right drivers for V2:
https://github.com/nanovna/NanoVNA-QT/releases/download/20200507/CypressDriverInstaller_1.exe
*73 de Luís, CT2FZI*
*QRV @ 145.300 MHz | **CQ0VMST (VHF REP Monsanto)*
<http://goog_717545661>
http://www.ct2fzi.net
On Thu, 22 Oct 2020 at 20:44, viger3it via groups.io <viger3it=
yahoo.it@groups.io> wrote:
viger3it 2020/10/23 01:42
HI CT2FZI,
thank you for the prompt reply,
I have already installed the driver you suggest, anyway I reinstall it following your iindicated web site but I have still the same result:
when I connect the USB cable from VNA we can heard the sound of PC that confirm the device detection but nothing else happen.
Must I do some action in the VNA or what ? Nothing user instructions are annexed to the VNA arrived !!!
Many thanks
73 de IK5BEQ
Giorgio
quetzalcoatl_pl 2020/10/23 11:06
You may have noticed that already, but V2 has a power on/off switch on the
left side of the screen.
Connect V2 to the PC and try flipping the switch and see if anything
happens - does it start up? does the screen blink at least? does your PC
play any sounds like finding/losing some usb connection?
reqards,
q/t.p.
pt., 23 paź 2020 o 10:42 viger3it via groups.io <viger3it=yahoo.it@groups.io>
napisał(a):
> HI CT2FZI,
> Many thanks
> 73 de IK5BEQ
> Giorgio
We define the boundaries of reality;
they don't define us
-- Teferi
Siegfried Jackstien 2020/10/23 09:40
giorgio wrote "when i connect i can hear pc sound "tading" (connection
found)
so giorgio at least you now know it works
if you fire up vna qt or nanovna saver you have to "connect" to the
device ... it does not do autoconnect
Am 23.10.2020 um 09:06 schrieb quetzalcoatl_pl:
Reinier Gerritsen 2020/10/23 11:50
Look at the Windows device manager. There should be a COM port. If there
is no COM port, then there is a driver problem. Last major Windows
update 2 weeks ago ruined my driver, I had to fix that. There is
probably an "unknown device", update its driver with Windows default
settings. Then a COM port will appear and VNA_QT will work after you
select the COM port in the Device menu.
Reinier
Op 23-10-2020 om 11:40 schreef Siegfried Jackstien:
> found)
> greetz sigi dg9bfc
>> on the
>> reqards,
>> q/t.p.
>> napisał(a):
>>> HI CT2FZI,
>>> instructions are
>>> Many thanks
>>> 73 de IK5BEQ
>>> Giorgio
IDcircuits - RFID & Electronics
Het Halster 40
6581 JL Malden
The Netherlands
+31 633702492
www.idcircuits.com
r.gerritsen@idcircuits.com
viger3it 2020/10/23 12:26
Hi there,
many thanks to all the people that give me informations .....now I CAN CONECT THE PC , ALL WORK OK !!!!!!!!!!!!
Many Thanks
73 de IK5BEQ
Giorgio
