Does anyone know of a manual for the PC application? It looks like a very
helpful means to communicate with the nanoVNA V2 but it has no Help or
About tab, so I am curious if you have any links.
Thanks!
Sam M.
Thanks!
Sam M.
the autor of the soft made it so userfriendly that he thought a manual
is not needed
in view you can set your scales (be it +30 to -80 or +10 to -100)
under device you can set your sweep range ... and with advanced settings
you can add some average
in main gui you will find on right side the calibration ... in principle
same thing as it is on the devive itself ... open short load through
soooo .... nothing special ...
a programmer can spent his time in programming ... or write a superb
manual ... but not both ;-)
ps nanovna saver and nanovna_app are two other soft that work superb
with the v2 ... wink wink
Am 19.11.2020 um 20:18 schrieb Sam Mallicoat:
Thanks Siegfried,
That’s right, programmers in open source projects expect the code itself to
be self explanatory. Thank you for your observations, perhaps I’ll add
these features as time allows.
Best regards,
Sam Mallicoat
On Fri, Nov 20, 2020 at 7:26 AM Siegfried Jackstien <
> the autor of the soft made it so userfriendly that he thought a manual is
> not needed
> greetz sigi dg9bfc
> ps nanovna saver and nanovna_app are two other soft that work superb with
> [image: image.png]
> Thanks!
> Sam M.
Sam Mallicoat
