Problems with V2 +4
Jonathan Peakall 2025/10/03 15:50
I have a V2 +4 that is not working for measuring VSWR on VHF/UHF. It works fine on HF. It also won't do a firmware update, it gets a white screen when holding down the left button when booting up. It also will not connect to a PC, it doesn't show up as a com port, even with the win10 driver installed.
Any ideas if this might be reset/fixed somehow? Or is it just borked?
Siegfried Jackstien 2025/10/04 21:06
try a different cable.. maybe it's just a charge cable?? or does not make good
contact??
in normal mode or in bootloader mode it should be found as a comport!!!
white screen is normal if switched to bootloader mode
dg9bfc Sigi
Am 04.10.2025 00:50 schrieb Jonathan Peakall <jpeakall@madlabs.info>:
Colin 2025/10/04 12:20
Make sure your cal standards are good and try doing a reset in the cal menu before doing the calibration on vhf? I was getting lots of very strange results on my SV4401a till I figured that out. It's basically a Nano with a big screen and N sockets.
Colin.
Jonathan Peakall 2025/10/05 13:36
Did all that. No joy.
On 10/4/2025 12:20 PM, Colin via groups.io wrote:
Colin 2025/10/06 06:49
How about a factory reset, and/or a firmware upgrade or reload?
Beyond that, I'm afraid it's terra incognito to me - anything that works past UHF, or made in the last 5 years, is just witchcraft!
Good luck,
Colin.
Jonathan Peakall 2025/10/06 07:35
I've been looking for how to do a factory reset but can only see how to
do that through a PC. Which I can't seem to connect to. Is there any
other way?
On 10/6/2025 6:49 AM, Colin via groups.io wrote:
cocopuppy 2025/10/09 11:21
You can check and see of the SMA solder joints were cracked
