Offset delay
canale 2020/12/20 07:16
Hi
I calibrated my VNA, now I would like to caracterize some additional SMA standards built by myself to use them as standards for a friend of mine.
The parameters needed are the offset delay of the additional SMA.
How can measure them for my additional standards using the NanoVNA-saver ?
G. Canale
Siegfried Jackstien 2020/12/21 15:14
KUURRRTTTT where are you?!? :-)
its not that easy to measure or fabricate a cal kit but its doable
kurt made a lot of work to measure n and sma (and other) kits and
describes how to make your own ... how to accurate measure them and how
to use that data in saver or qt
KUUUUUURRRRTTT ... help this guy please (it way to complicated to answer
that in a short mail)
https://www.sdr-kits.net/calibration-information-for-DG8SAQ-VNWA-3-3EC
https://youtu.be/gATrqw4lKT8
http://www.hamcom.dk/
Am 20.12.2020 um 15:16 schrieb canale via groups.io:
canale 2020/12/21 22:13
Thank you Siegfried
Siegfried Jackstien 2020/12/22 13:59
Youre welcome...
Thank kurt... He made all the work
Am 22.12.2020 07:13 schrieb "canale via groups.io"
<gf.canale=libero.it@groups.io>:
> Thank you Siegfried
Kurt Poulsen 2020/12/27 13:41
Hi Siegfried
I AM HEEEEREEE
I will respond to the Canale
Kind regards
Kurt
Fra: NanoVNAV2@groups.io <NanoVNAV2@groups.io> På vegne af Siegfried Jackstien
Sendt: 21. december 2020 16:14
Til: NanoVNAV2@groups.io
Emne: Re: [nanovnav2] Offset delay
kurt made a lot of work to measure n and sma (and other) kits and describes how to make your own ... how to accurate measure them and how to use that data in saver or qt
KUUUUUURRRRTTT ... help this guy please (it way to complicated to answer that in a short mail)
Hi
G. Canale
Kurt Poulsen 2020/12/27 14:31
Hello Canale
It is very limited information you provide about your home made calibration standards. If the frequency of interest is HF up to 30MHz there is a simple method using the NAnoVNA saver.
After calibration of the VNA then measure the Open homemade standard and chose a phase trace and in the calibration settings tune the Offset delay until the phase trace is “flat” showing 0 degree for the frequency span selected and you have found the open one way delay.
Set it back to 0 delay and chose an imag Z trace and measure the Short home made calibration standards and tune the Offset delay until the image impedance is 0 ohm across the frequency span and you have found the short one way delay.
If you do not obtain these two “flat” traces return to the matter here again, as you the have other consideration to deal with
Kind regards
Kurt
Fra: NanoVNAV2@groups.io <NanoVNAV2@groups.io> På vegne af canale via groups.io
Sendt: 20. december 2020 16:16
Emne: [nanovnav2] Offset delay
Hi
G. Canale
canale 2020/12/27 06:16
Hi Kurt
thank you for your reply.
The maximum frequency of interest for me is 3GHz.
I understand your indication but there is still a point that I do not understand.
You say " in the calibration settings tune the Offset delay until the phase trace is “flat”
Can you please give more details about where in the calibration setting pan I should trim the
offset delay during the measurement of my home made standard ?
I use the Nanovna-saver-0.3.3
Thank you
Gianfranco
canale 2020/12/27 08:38
Hi Kurt
I understood .
Sorry for the unconvenience.
G. Canale
Siegfried Jackstien 2020/12/27 18:13
A sidenote... Saver 0.33 is very old
We are at 0.38 now
If you have problems they may have been solved in a later version
Means... Use new saver... And actual fw
Greetz sigi dg9bfc
Am 27.12.2020 17:38 schrieb "canale via groups.io"
> Hi Kurt
> I understood .
> Thanks
> G. Canale
Kurt Poulsen 2020/12/28 00:13
Hi Gianfranco
In this menu. Maybe when going to 3GHz the phase and ImagZ will not be flat. Provide some screen images if not
Kind regards
Kurt
Sendt: 27. december 2020 15:16
Hi Kurt
You say "in the calibration settings tune the Offset delay until the phase trace is “flat”
Thank you
Gianfranco
canale 2020/12/27 22:08
Hi Kurt
very clear, problem solved.
Gianfranco IZ2ZNC
PETER LAWRENCE 2020/12/29 10:18
I used to be able to use my early SMA version 2.8" running v3.7 ,
and my 'N' type 4" running v2_2 or QT, from my win7 desktop.
that broke so now have to use win 10 or win 10 pro.
Got the 2.8" working though I would like version 3.7 or later, if I
could be sure how to do it.
Tried every version I can find for 'N' 4" without success.
The QT version seems to install, including the driver, but always get
the error message attached.I tried every USB port, confirmed via Device
Manager, but Refresh always returns Com 3. and error when I try to
connect.
Peter
------ Original Message ------
From: "Siegfried Jackstien" <siegfried.jackstien@freenet.de>
To: NanoVNAV2@groups.io
Sent: Sunday, 27 Dec, 20 At 17:13
Subject: Re: [nanovnav2] Offset delay
We are at 0.38 now
Greetz sigi dg9bfc
Hi Kurt
I understood .
G. Canale
Siegfried Jackstien 2020/12/29 13:13
use saver 38 and use an actual fw ... and set avg to none and save that
in slot 0 ... then saver works fine
if you se ag to say x5 and try to use saver thzen the soft ask for 100 p
but gees only 20 back ...
if averaging needed then use avg in the soft but in device set to none!
here all three soft do work fine ... with v2, v2plus and wih plus4
Am 29.12.2020 um 10:18 schrieb PETER LAWRENCE via groups.io:
barnc4br 2020/12/29 05:52
Offset delay
Hi
If you verify your calibration using the additional standards you will see the diff between what you calibrated with and those units. Now if you did the cal with pricey standards then you have a decent characterization.
canale 2020/12/29 06:30
Good idea
