New To Group and the NanoVNA
Tim 2023/11/18 16:14
Greetings To All,
I am new to this group and the using of a NanoVNA-H4. I am having throuble understanding a few fuctuions of the NanoVNA.
1. After set up my frequecies to match my HF6V (80, 40, 30, 20 15, 10 mm), when I hit the Recall setting the frequencies no longer have the S11 SWR settings. I have to go through the process of setting it up each one once more. Is there a way to save all setting related to the frequency and SWR settings?
2. Is there away of identify the 9 horizontal lines as 1.0 SWRs through 2.0 SWR?
3. Do I need to calibrate (Open, Short and Load) the NanoVNA each time I use it?
4.I am required to calibrate each frequncy (80, 40. 30, 20, 15 and 10mm) individually each time I use the NanoVNA?
5. Can the Open, Short and Load calibration be save with the six frequencies saved under Recall?
Thank you for any advice provided.
John Gord 2023/11/18 22:38
Tim,
This group is mainly about the NanoVNA-V2, which operates up to 3 GHz and beyond,
The NanoVNA-H4 is better covered on another group:
https://groups.io/g/nanovna-users
On Sat, Nov 18, 2023 at 07:58 PM, Tim wrote:
