Nanovna v2 s-a-a-2 recognized by pc-usb as optical mouse most of the time, not /dev/ttyACM0 or the like (linux, same problem on windows)
alfredo.crolle 2022/08/17 11:17
either switching first nanovna v2 s-a-a-2 and thereafter connect to pc, or viceversa, COM port does not appear on PC (/dev/ttyACM0) on linux.
This is what I see on linux most of the time:
Aug 17 20:05:06 Aspire-5755G kernel: [27196.807199] hid-generic 0003:093A:2510.000C: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1d.0-1.4/input0
Aug 17 20:05:06 Aspire-5755G mtp-probe: checking bus 2, device 14: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4"
Aug 17 20:05:06 Aspire-5755G mtp-probe: bus: 2, device: 14 was not an MTP device
Aug 17 20:05:06 Aspire-5755G upowerd[1344]: treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4
Any help ?
Alfredo
Vladimir Lebedev 2022/08/17 12:03
Hello Alfredo!
For Windows AS FIRST!  download and install Cypress driver:
https://nanorfe.com/downloads/NanoVNA-QT/CypressDriverInstaller_1.exe
Best regards
Vladimir , dl7pga
alfredo.crolle 2022/08/17 14:37
I changed usb cable (again) and now it works, both on Win 10 and Linux.
I do not understand why suddenly usb cable do not work anymore (it happened me a few times in the past).
All connections seem ok.
So, .... problem seems to be solved ...hopefully.
PS:
I own a "Zeenko" bought from Amazon, I have yet to understand if it is a clone or not, because this seller is "banned" as not-authorized NovaVNA V2 maker in the NanoVna site, but everything seems to work, up to now ...
Moreover ...,
Do You know if s-a-a-2 V2 hw (2.8 inch sceen) can load the latest sw for "Plus" version with bigger touch screen ?
(I loaded 20201013 firmware, that looks like to be the latest (see site) for this hw .... not very sure... indeed....)
Thanks ,
Alfredo
Siegfried Jackstien 2022/08/18 20:32
you have to use a fw for the small screen
the saa2 is a nanovna v2 ... nothing special (no plus!!)
so any fw for v2 should run on the saa2 if it is made for the 2.8 inch
screen
ps there is a "beta test group" where a user "dislord" makes very nice
fw .... nanovna-beta-test@groups.io
Am 17.08.2022 um 23:37 schrieb alfredo.crolle via groups.io:
