NanoVnaV2 Plus4
Simone Guagliumi 2026/01/23 15:05
questo gruppo è anglofono, se vuoi risposte devi scrivere in inglese.
this group is english-speaking if you want answers you should write in
english
Simone
Il 20/01/2026 12:09, i3gxc via groups.io ha scritto:
i3gxc 2026/01/24 17:40
Good morning everyone, I'm having a problem with the NanoVna V2 Plus4.
I tried updating the firmware and everything went well
until the end, but then when I turned it on, the screen remained completely WHITE
and since then I haven't been able to do anything.
If anyone can help me solve the problem,
I'd be really grateful.
Greetings everyone,
Claudio i3gxc
Thanks for your reply. In any case, I don't need any help because I've solved the problem.
W4JDY1953_G 2026/01/24 12:14
Well, some of us can read and speak more than one language.
Use the browser apps and respect the fact that not everyone is English speaking.
Tu sai Americano non vero !!!
Alois Kaiser 2026/01/25 11:08
Hello, I had the same symptoms with my original VNA. The board in my VNA
was defective. It was replaced, and everything worked as usual. I've
since downloaded the latest firmware, and everything is fine.Best
regards, Alois OE6AKS
Am 23.01.2026 um 15:05 schrieb Simone Guagliumi via groups.io:
Colin 2026/01/25 06:28
Google Translate does a pretty good job though!
I haven't had any problem with upgrades - so far!
Will it not even let you try reloading the original firmware?
Colin
Siegfried Jackstien 2026/01/27 14:44
maybe wrong FW used?? what soft did you use to upgrade the unit?
I use nano vna app from discord and also the newest fw from dislord
.. we need some info to help you
dg9bfc Sigi
Am 25.01.2026 15:28 schrieb "Colin via groups.io"
<mm1aps=btinternet.com@groups.io>:
> Colin
Dave Johnson 2026/01/30 16:14
Sounds like you may not have used the lastest official from NanoRFE, and instead used a newer version from dislord or something ?
The dislord versions only support the very first V2plus4 versions that used a display with an open-source driver. Shortly after that, NanoRFE swapped the display with one that requires a proprietary driver, which means that none of the other versions will work.
Reflash with the "latest" Jan 2025 version from NanoRFE and see if it doesn't resolve your problem:
https://nanorfe.com/nanovna-versions.html
-=dave
i3gxc 2026/01/31 18:05
Hi Siegfried DG9BFC,
thanks for the info but I've already solved the problem.
I had installed the firmware version 20220814 which was the stable one,
instead I managed to load the V 20250121 and thus restored
Thanks 73 de i3gxc Claudio
i3gxc 2026/02/01 15:18
Hi Dave,
I tried looking at the firmware link you sent me
(https://nanorfe.com/nanovna-versions.html),
and it tells me to re-flash with the "latest" version of NanoRFE,
January 2025. But on that link, I only see versions 20250121
latest and 20220814 stable. I tried installing version 20220814,
but it froze, so I reinstalled version 20250121 and it restarted.
If you could tell me which version you mentioned
in your email and the exact link, thanks,
Claudio.
Dave Johnson 2026/02/05 08:05
Thats the one.
-=dave
