*NanoVNA 2.4 (F/W 20250121)*
Hello, last 6 months touch panel worked very unstable and finally stopped to work two weeks ago.
i disconnected panel from device and tested it using Arduino + ST7796S Gfx lib + XPT2046 lib - it works!
I soldered the processor pins - no luck, display works but without touch panel. I bought 4.0 inch LCD panel on Ali (the same ST7796 and dimensions) - same, touch panel does not work
so, everything works except touch panel
what happened ? died T-IRQ -> cpu input pin ?
