Nano VNA V2 Plus4 pro
inotech 2023/11/11 01:31
Is a schematic available for this unit ?
I need to identify the surface mount component that is in series with port 1 SMA (port closest to power slide switch)
centre pin. Component is located on the underside of the board under the metal can shield.
I may have damaged this component during the process of replacing the SMA connector.
No guessing please....
Thanks & Regards,
Oli.
nanov2support 2023/11/11 03:01
Hi, it should be a 10uF 10V ceramic capacitor, to be sure you can send me a photo of the area and I can check.
inotech 2023/11/14 13:41
Attached picture showing 'TOMBSTONE' component, this happened during the process of de-soldering Port 1 (CH0) SMA, the component has been placed back onto its pads, however i need to measure that its value is correct.
Could you please confirm the PCB through hole diameter for the SMA centre pin via.
Thanks & Regards,
Oli.
nanov2support 2023/11/14 18:32
Hi, the component is a 10uF 10V capacitor, and the via size for the SMA center pin is 1.2mm.
inotech 2023/11/15 02:30
Thank you.
Excellent support.
inotech 2023/11/25 21:49
Nano VNA V2 Plus4 Pro
Please provide part number for a replacement slide power switch,
my switch has become intermittent.  Switch labelled S2 on PCB.
Oli.
nanov2support 2023/11/26 08:34
Hi, the part number is SK-12D02VG4,
https://www.lcsc.com/product-detail/Slide-Switches_SOFNG-SK-12D02VG4_C239529.html
inotech 2023/11/27 12:53
Once again,
Great support..
Thanks & Regards,
Oli.
