NANOVNA-Saver Help
JRW 2025/07/24 13:49
Greetings Readers,
The program " nanovna-saver.exe " did run on my laptop. Now it refuses to run and returns the following messages :
Quote:
Traceback (most recent call last):
File "NanoVNASaver\__main__.py", line 128, in <module>
File "NanoVNASaver\__main__.py", line 105, in main
File "NanoVNASaver\NanoVNASaver.py", line 270, in __init__
File "NanoVNASaver\Windows\DisplaySettings.py", line 286, in __init__
File "NanoVNASaver\Windows\DisplaySettings.py", line 360, in _chart_selection
File "NanoVNASaver\Windows\DisplaySettings.py", line 419, in changeChart
File "NanoVNASaver\NanoVNASaver.py", line 662, in copyChart
File "NanoVNASaver\Charts\TDR.py", line 301, in copy
AttributeError: 'PySide6.QtWidgets.QDialog' object has no attribute 'updated'. Did you mean: 'update'?
Un Quote
Does anybody have an idea as to how to get this program to work ?
Many thanks in advance,Jeremy
Rick Kunath 2025/07/25 12:39
What distro? Any updates done?
What Python version 3.1.3.5 is the latest, any older Python versions
hanging around that you don't know you need?
Are all of the package deps met? Check that with your package manager.
Is QtWidgets up to date?
Rick Kunath, K9AO
Dave (G1OGY) 2025/07/25 18:36
What version are you attempting to run, Jeremy?
NanoVNASaver 0.3.8 runs on my W11 box.
Version info should be printed on the first line of the black `Command`
window.
check the contents of and perhap delete
%appdata%\Roaming\NanoVNASaver\NanoVNASaver.ini
On Fri, 25 Jul 2025 at 17:04, JRW via groups.io <wallerjr=
bigpond.com@groups.io> wrote:
W4JDY1953_G 2025/07/25 16:59
Same here ….
W4JDY
Email to be sent never is to fix the problem.
JRW 2025/07/26 08:22
Thank you so much every body for the replies.
The problem has been fixed. How? You may ask. Well, I am not a
programmer. I was told by sundry people that I only know enough to be
dangerous. Well I , eventually, found the *.ini file and deleted it and
Lo and behold the program worked!
Where is the *.ini file? In my case it is in the directory on drive c:
... Quote from my notes:
c:\Users\****\AppData\Roaming\NanoVNASaver\*.*
Files:
NanoVNASaver.ini
       Bands.ini
73's to all
Jeremy.
On 25/07/2025 20:59, W4JDY1953_G via groups.io wrote:
