INFORMATION about Japanese-origin Hacker Software for NANOVNA V2 PLUS4 for measuring quartz and quartz filters
Loris Bollina 2025/08/30 07:25
Hello everyone, I own a NANOVNA V2 plus4 purchased from the official website, and as reported there, it doesn't measure crystals and tends to have problems measuring narrow-band crystal filters (SSB and CW).
I found this software online that should solve the problem:
v2plus4-ojisankoubou.bin.
It's available on the developer's Japanese website:
https://ojisankoubou.web.fc2.com/index.html
and also in this group:
https://groups.io/g/NanoVNAV2/topic/v2_plus4_ojisankoubou/83997806.
QUESTIONS:
Has anyone tried it?
Is it reliable?
Do you think it can charge without problems, or do you not recommend it?
Johann 2025/08/30 17:30
If you read carefully it is clear that it is for a NanoVNA v2 SAA2 clone.
I am sure it will brick firmware!
I wouldn't risk it on a 100% original from Tindie!
(I have a NanoVNA V2 plus 4 and an older compatible clone of course not
compareable to original - which has much better response above 2GHz))
Diese Nachricht wurde von meinem Android Mobiltelefon mit GMX Mail gesendet.
Am 30.08.25, 16:25, "Loris Bollina via groups.io"
> <https://ojisankoubou.web.fc2.com/index.html>
> <https://groups.io/g/NanoVNAV2/topic/v2_plus4_ojisankoubou/83997806>.
> QUESTIONS:
> Is it reliable?
Johann 2025/08/30 10:50
Hello all,
I have a NanoVNA v2 Plus 4 Pro from Tindie and an older NanoVNA 2.2  100% compatible Clone for comparison purposes. (Of course Tindy Original response is much better on original then on clone!)
I would not risk it to use different firmware - even if some people got it working on originals !
If you read carefully this firmware were originally developed for a NanoVNA v2 Saa2 clone!
Chances are definitely higher to brick it, than with original firmware !
Loris Bollina 2025/08/31 22:49
Thanks for the reply... OK... as soon as I can, I'll buy a PLUS 5 and put the PLUS 4 up for sale!
Best regards
Carsten F (OZ1FTG) 2025/09/01 22:11
According to this post , and attachment
OwO adapted the "japanese" fw to run on a V2 Plus4.
The  V2 Plus4  firmware is attached to OwO's message
