Error unable to connect to mac
Robert galambos 2020/06/29 16:57
I Dl the Mac version of vna-qt
Got to work once,  but no longer.
Device not found
In the  dmesg
Config-recall incorrect magic FFFFFFFF, should be 80081235
Touch cal:
1950, 1900
-90,     -120
Help
⁣DEC for YORK & DURHAM Region ARES.
ASEC GTA ARES section
M: +1-416-876-2979
H:  +1-416-227-1414
E:   va3bxg@gmail.com
WL: va3bxg@winlink.org
When all else fails​
reuterr 2020/06/29 14:19
On Mon, Jun 29, 2020 at 10:56 PM, Robert galambos wrote:
> Device not found
Hello Robert,
I am using MacOS Mojave 10.14.6.
vna_qt.app works fine, you should see the USB device /dev/cu.usbmodemDEMO1
See attached menu Device: vna_qt_Device-menu.png
73, Rudi DL5FA
Robert galambos 2020/06/29 19:02
It did work for one time. It fails thereafter.
M: +1-416-876-2979
H:  +1-416-227-1414
E:   va3bxg@gmail.com
On Jun. 29, 2020, 17:19, at 17:19, reuterr@web.de wrote:
Robert galambos 2020/06/29 21:09
Tried the nanovna-saver with the same issue.
Is there a way to reset the software to factory, without a USB?
M: +1-416-876-2979
H:  +1-416-227-1414
E:   va3bxg@gmail.com
On Jun. 29, 2020, 19:01, at 19:01, "Robert galambos via groups.io" <va3bxg=gmail.com@groups.io> wrote:
