Charging the H4
Jtb4079 2025/05/30 02:07
I "think/know" that I just "bricked" my H4 by connecting it to a Apple fast charger - using a C type to C type cable.
I tried to replace the chip but manged to damage the PCB in the process, hence the new one.
Is this a known feature for older H4 and do the newer versions suffer the same issue?
It would be a shame to find out the hard way - again!
Cheers John
A Sadlon 2025/05/30 14:52
I smoked my H4 by using a fast charger also. It will still operate
hooked up to an external battery source via USB.
On 5/30/2025 05:07, Jtb4079 via groups.io wrote:
Jtb4079 2025/06/04 11:27
The regulator chip "burnt" out and I damaged the PCB in an attempt to replace it -hence the toasted H4!
There is a warning about max charge rate but there's no mention of not using a fast charge - presumably most nano users are aware of this danger?
W0LEV 2025/06/05 18:04
The most robust charger I've used for any of my NANOVNAs or TinySAs is 1.5
amperes at 5.5 vdc. No problems for over 3 years of owning these.
<http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.www.avg.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
On Thu, Jun 5, 2025 at 4:21 PM Jtb4079 via groups.io <Jtb4079=
David J Taylor 2025/06/06 07:06
> Dave - WØLEV
It seems that some modern chargers are incompatible with some devices, or the
other way round! It's safest to stick with a 5V only charger and not one which
offers multiple output voltages.
Read the specification of the target device carefully - it may say "5V only" and
it means that! For example, the tinySA Basic, the Wiki has: "(5v DC) USB
charge" in:
https://tinysa.org/wiki/pmwiki.php?n=Main.FirstUse
David
Email: davidtaylor@writeme.com
BlueSky: @gm8arv.bsky.social, Twitter: @gm8arv
