Any recommendations on what standards to order for calibration? The kit linked from the website shows as out of stock.
Depending on your frequency requirements, there are a number of online
"recipes" on how to make your own calibration standards. I'd do a www
search for that if you are so inclined.
On Thu, Nov 20, 2025 at 2:29 PM aggie120684 via groups.io <aggie120684=
NanoVNA V2 and VNA6000 from NanoRFE come with a cal-kit.
If you need another then the choice may pivot on your use-case.
For Low Band and HF uses you may well be able to get away with one of the
`silly-cheap` options available via eBay or AliExpress.
Otherwise, for GHz ranges, you may wish to expend more effort and you are
limited only by your budget. Even for non-traceable parts you can pay
(well) over the price of the instrument itself for a SOLT kit. And then
there's the phase-matched cables... And the female kit...
In the end none of it is definitive; there are margins of error, even with
`Pro` equipment.
On Thu, 20 Nov 2025 at 14:32, aggie120684 via groups.io <aggie120684=
`Pro` equipment.
If you need a traceable set of standards (I do work for clients) I can recommend Kirkby Microwave: https://www.kirkbymicrowave.co.uk/
He will also recertify/recharacterize standards.
They are not cheap but almost an order of magnitude cheaper than Keysight, etc. kits.
I have also seen some kits from Asia on EBay but their traceability and characterization are questionable IMO.
73, Don N2VGU
73, Don N2VGU
