vna v2 ... or quite similar ... but improved design
Siegfried Jackstien 2020/07/29 08:00
found in the net
http://www.yl3akb.lv/content/vna_v2/vna_v2.php
with a different clock it goes up to 6 gig
and it seems as this is a real 2 port and not a 1 plus a half port design
aleks07111971 2020/07/29 08:31
https://www.eurovna.net/en/eurovna/software/
aleks07111971 2020/07/29 10:29
Kroks(RU)
1000 $
dekagon 2020/07/30 14:15
@aleks
is this a 2-port vna from Arinst?
They did not have a 2-port vna till now...
Chris
'Everything should be made as simple as possible, but not simpler.' -- Albert Einstein
Am 29.07.2020 um 19:29 schrieb aleks07111971@yandex.ru:
> Kroks(RU)
> 1000 $
Chris
I am not responsible for typos... they always respond to the bad robot...
aleks07111971 2020/07/30 05:32
Yes.
dekagon 2020/07/30 14:48
Do you have some specs (in english if available please).
The website from arinst does not help...
Chris
> Am 30.07.2020 um 14:32 schrieb aleks07111971@yandex.ru:
> Yes.
Chris
aleks07111971 2020/07/30 06:18
Portable vector and spectral two-port analyzer 1-6200 MHz.
Large touchscreen display and no buttons, except for one - power.
So far, everything I know about this device.
dekagon 2020/07/30 16:33
Thank you.
Any infos when they will sell it?
Chris
> Am 30.07.2020 um 15:19 schrieb aleks07111971@yandex.ru:
Chris
aleks07111971 2020/07/30 07:47
There will be 2 ports.
1 port vector measurement S11, calibrated generator with level control -40 ... 0 dBm
2 port vector measurement S21, calibrated receiver with spectrum analysis function -120 ... + 10 dBm
The planned isolation between ports inside the device is not worse than 60 dB, it may be possible to bring up to 80 dB at frequencies below 3 GHz
aleks07111971 2020/07/30 07:52
I'll try to ask the developer.
dekagon 2020/07/30 17:17
Sounds interesting...
Thank you :)
Chris
