Hi, just received my nanovna V2 plus 4, but don't have a battery as yet. Just like to check that there are no issues with powering it up for the first time via USB without a battery fitted?
Andrew
Andrew
There was a message on here some time back that it was okay to run it
without a battery. I just got mine a few days ago and have used it
without the battery. Still looking for a battery to put in mine.
Mick - W7CAT
----- Original Message -----
To: NanoVNAV2@groups.io
Sent: Tuesday, June 29, 2021 06:35:13 AM
Subject: [nanovnav2] powering without a battery installed
> Thanks,
> Andrew
Untitled Document
Sure you can do that.
Op 29-6-2021 om 14:35 schreef Andrew via groups.io:
> Thanks,
> Andrew
Dit e-mailbericht is gecontroleerd op virussen met Avast antivirussoftware.
https://www.avast.com/antivirus
it should work without battery
any "normal" 18650 cell should fit (crack a defective notebook battery
open or wherever you may find an 18650 cell)
Am 29.06.2021 um 14:35 schrieb Andrew via groups.io:
Dear all,
The NVNA Plus 4 come without a battery?
El mié., 30 jun. 2021 4:03, Jos Stevens <jrs@xs4all.nl> escribió:
On 30/06/2021 18:35, Esteban H wrote:
> Dear all,
> Regards
I found there was an option to purchase with, or without, but the
shipping cost was greater with the battery, and could only be done by
DHL (IIRC).
David
Thanks.
El mié., 30 jun. 2021 19:04, David J Taylor via groups.io <david-taylor=
blueyonder.co.uk@groups.io> escribió:
Thanks all for the replies!
I have powered it up via usb and it appears to be working so that's great!
Now to source a battery, and thanks for the tips about that.
Andrew
the second type of power source affects the measurement values.
On Thu, 1 Jul 2021, 03:50 Andrew via groups.io, <irbsurfing=
yahoo.co.uk@groups.io> wrote:
Can anyone recommend a reliable source for the 18650 cells in the U.S.
> On Thu, 1 Jul 2021, 03:50 Andrew via [groups.io](http://groups.io),
> Regards,
> Andrew
I have found a source for the cells - Battery Source.
Is the flat top battery the proper type?
> Mike N2MS
> Regards,
> Andrew
> Mike N2MS
Yes, at least for the NanoVNA V2 Plus4.
David GM8ARV
Yep. Flat top. I got a Panasonic 3400 mAh. I haven't timed it, but it goes through the battery relatively quickly so higher capacity is beneficial.
Thanks for the information.
I gave the wrong name for the supplier. The company I am looking at is Battery Junction.
Dear Zeljjo,
Could you provide a link where the behaviour you indicated ("affects
measurements") is explained?
Esteban.
El jue., 1 jul. 2021 7:12, zeljko adzic <agamotori@gmail.com> escribió:
I got mine from https://www.18650batterystore.com/
Hi Mike,
I've used a couple of different brands from Amazon.com with good results
but I see that neither of them is currently available. So, I search for a
YouTube video and found *THIS <https://www.youtube.com/watch?v=qMZuHMlRw_0>*
one. After watching it, I guarantee you that I will *NEVER *buy a Chinese
battery, *AND *those that claim to provide 9,999 mah, or anything above
3,500 mah for that matter, are *ABSOLUTE LIARS*! 🤬
Don, W5MML...🤠
On Thu, Jul 1, 2021 at 8:33 AM n2msqrp <mstangelo@comcast.net> wrote:
I ordered LG batteries.
On 03/07/2021 21:55, Don Bomer, W5MML wrote:
> Hi Mike,
> a YouTube video and found *THIS
> <>* one. After watching it, I
> guarantee you that I will *NEVER *buy a Chinese battery, *AND *those
> that claim to provide 9,999 mah, or anything above 3,500 mah for that
> Don, W5MML...🤠
Indeed, an interesting video. There are lots of sites with hints on how
to tell fake 18650 batteries:
https://batterybro.com/blogs/18650-wholesale-battery-reviews/30828867-is-it-a-fake-18650-battery-featuring-the-samsung-25r
is but one example. I recently bought 4 18650 "3400 mAh" batteries
/and/ a torch for GPB 20, accepting that they were likely fakes:
https://www.amazon.co.uk/gp/product/B08C74D9PP
They measured 2717, 2757, 2820 and 2828 mAh, when checked with this charger:
https://www.amazon.co.uk/gp/product/B07G7Z9P5H
David GM8ARV
