nanoVNA v2plus5 : RBW register
Yohan Le Diraison 2023/03/30 15:09
Dear All,
I got a NanoVNA v2plus4pro. I use it over an USB connection on a
personal software for my company. I wan't to be able to manage the BW
parameter, like the UI firmware do. Unfortunately, I can't find the last
firmware source code, it's not up-to-date, or moved years ago from
https://github.com/nanovna-v2/NanoVNA2-firmware, or maybe I miss something.
Does someone knows which is the BW register and its data
configuration/meaning, and where to find the last firmware source code ?
Best regards,
Yohan Le Diraison
nanov2support 2023/03/30 07:51
Hi, the bandwidth setting can be changed by writing one byte to register 0x42.
The supported values are 5, 10, 20, 30, 40, and 60, corresponding to IFBW 0.8kHz, 1.6kHz, 3.1kHz, 4.7kHz, 6.2kHz, and 10kHz.
Yohan Le Diraison 2023/03/30 18:02
Le 30/03/2023 à 16:51, nanov2support a écrit :
lodge_shiatsu0h 2024/05/12 09:18
Hi Yohan, did you find a way in the end?
