nanoVNA-Saver comments #nanovna-saver
Anne Ranch 2022/06/14 11:43
This is not a complaint, just an recent new user observations.
NanoVNA displays results of test practically instantly and automatically AFTER “menu” is
exited.
NanaoVNA-Saver ( 0.4.0) “sweep” is manual and painfully slow...
Is the “problem “ in low serial baud rate ?
There is no visible means to set / configure the baud rate , or did I missed it ?
Secondly – I can “zoom” the “VSWR” (vertical) scale, using mouse wheel, but there
is no “unzoom” .. ( “Reset” does not always do “restore “ )
Personalty , and in case of "VSWR" ,
it would be nice to be able to move the view - both vertically and horizontally or
"zoom to area"...
( PS I do not do "python" - so I cannot "be partof the solution  - and code ..." )
Cheers
Jim Lux 2022/06/14 13:07
> exited.
> missed it ?
I don't think it's the baud rate (it's a USB pseudo serial, so it is
very fast).  It might be how NanoVNA-Saver works - It *might* be some
aspect of how the windowing is done (using PyQT), and it has to go
through event loop and redraw.
When I do a sweep with a command line to the VNA using NanoVNA.py (which
uses the same underlying serial interface code) it comes back very
quickly. ~ 1 second.
time ./nanovna.py
{'rawwave': None, 'plot': False, 'smith': False, 'polar': False,
'delay': False, 'groupdelay': False, 'vswr': False, 'phase': False,
'unwrapphase': False, 'tdr': False, 'scan': False, 'start': 1000000.0,
'stop': 900000000.0, 'points': 101, 'port': None, 'device': None,
'verbose': False, 'capture': None, 'command': None, 'save': None}
port stub
1000000.0 900000000.0 101
set_frequencies 1000000.0 900000000.0 101
real    0m1.240s
user    0m0.583s
sys    0m0.392s
$jimlux$ time ./nanovna.py --start 50000 --stop 100000000 --points 101
-o xyz --port 0
'unwrapphase': False, 'tdr': False, 'scan': False, 'start': 50000.0,
'stop': 100000000.0, 'points': 101, 'port': 0, 'device': None,
'verbose': False, 'capture': None, 'command': None, 'save': 'xyz'}
port stub
50000.0 100000000.0 101
set_frequencies 50000.0 100000000.0 101
set_sweep 50000.0 100000000.0
command:sweep start 50000
command:sweep stop 100000000
command:frequencies
command:data 0
data length 2626
['1.003932833', '-0.000515787']
<snip out>
['1.015809059', '-0.026692859']
['1.016044139', '-0.027005475']
['1.016262888', '-0.027295954']
command:frequencies
real    0m2.888s
user    0m0.888s
sys    0m0.554s
 time ./nanovna.py --start 50000 --stop 100000000 --points 201 -o xyz
--port 0
'stop': 100000000.0, 'points': 201, 'port': 0, 'device': None,
port stub
50000.0 100000000.0 201
set_frequencies 50000.0 100000000.0 201
command:scan 50000 50025000 101
command:data 0
data length 2626
['1.003917217', '-0.000507782']
<snip out a bunch>
['1.007282853', '-0.013038916']
command:data 1
data length 2630
['-0.000000218', '-0.000000795']
[<snip out a bunch>
real    0m3.514s
user    0m0.916s
sys    0m0.553s
Anne Ranch 2022/06/15 08:18
Thanks, my comment on baud rate was just a "cheep shot" .
Perhaps I should  renew my interest in "python"...
I did try python about year ago, but got "turned of" by the syntax...
I have not done any real time graphs in QT , but as an event driven
concept ( QT) it should not be an issue.. ( just a comment again )
