nanoVNA Saver crashes under two situations with both the 64 bit and the x86 versions, newest downloads:
#1: When I first power everything up, plug everything in and then try to connect to the nanoVNA with the Saver program - CRASH!.
If, on the other hand, I connect to the nanoVNA using the VNA View program first, exit VNA View, then VNA Saver will connect without issue.
#2: This **used** to work just fine, but crashes every time now...probably due to a Windows update :-/ ...
I set up the sweep specifications with a single sweep segment. Sweeps just fine.
Change the number of sweep segments to anything but 1 and Saver crashes when you try to sweep. - CRASH!
