automating NanoVNA saverRe: [nanovnav2] Python or Matlab file for nanoVNA SAA2
Jim Lux 2021/07/06 07:26
On 7/6/21 6:26 AM, Albert Kleyn wrote:
> I have the NanoVNA SAA2 ( with the N type connectors)
> Mine works fine with the NanoVNA-Saver S/W
> As I mainly use it for Antenna measurements this does me fine.
> Albert
> EI7II.
Good news for Khalid..
I use NanoVNA-Saver a lot, but lately, i've been using a more stripped
down program nanovna.py (that is for the original ones only, I think),
because it has a useful command line interface.
I've been looking at NanoVNA-Saver to see if I could split it into a
front end/backend architecture - front end for the (optional) GUI, back
end for the "run the VNA" - but it looks to be a fair amount of work. I
like the multiplatform aspect of NanoVNA-Saver and a somewhat richer
feature set (i.e. calibrations).
Kevin O'Brien 2021/07/06 12:25
Hi Jim,
I also like the multi-platform aspects of NanoVNA-Saver, but wanted a
I wrote a simple Python script, attached, which provides a command line or
Jupyter notebook interface to the NanoVNA-Saver internals for calibration,
frequency domain measurements, and TDR measurements.
It worked well for a class I taught last semester using the V2 and V2Plus4.
Kevin
On Tue, Jul 6, 2021 at 10:26 AM Jim Lux <jim@luxfamily.com> wrote:
Jim Lux 2021/07/06 09:47
On 7/6/21 9:25 AM, Kevin O'Brien wrote:
> Hi Jim,
> line or Jupyter notebook interface to the NanoVNA-Saver internals for
> calibration, frequency domain measurements, and TDR measurements.
> V2Plus4.
> Regards,
> Kevin
This is quite nice.. thanks.. you should do a pull request and see if
you can add it to nanovna-saver...
