Which FW for V2 plus4?
Charles Luther, N8DD 2024/01/21 12:52
Just received nanoVNA v2 plus 4 from Tindie. I upgraded to the stable FW 20211227, and this led to spurious data on smith chart and SWR traces using the calibration standards following a calibration. However, I then switched to latest FW 20220814, and it worked fine and I get good data and traces with known antennas I have. I then switched back to FW 20211227, and the same problem occurred.
Is FW 20211227 defective? Why is it giving me obviously erratic and false traces while FW 20220814 works fine?
I did not take note of FW that it shipped with...I wish I did.
Charlie
nanov2support 2024/01/21 20:08
Hi, the firmware 20220814 is stable and is the minimum recommended version. Older firmwares may not work correctly with new devices.
NanoRFE Support
IW6BFE 2024/01/21 23:59
Hello @nanov2support,
in a previous post you declare that a new firmware should be released in October 2023 but nothing has been released yet.
Did you have a now release date ?
Arrio
