V2 Plus4 Pro questions
IW6BFE 2023/03/22 00:32
Hello all,
I' would like to purchase a nanovna V2 Plus4 Pro, but some informations miss or not match in various reviews.
What I would ask to V2 Plus4 Pro owner's is :
- Which is the minimum selectable IF in stand alone mode (no computer aid).
- Which is the minimum selectable IF in stand alone mode (no computer aid) with lastest firmware ?
- Which is the maximum number of sweep point in stand alone mode (no computer aid) with lastest firmware ?
73 de IW6BFE
Arrio
Mark Libner 2023/03/23 06:41
800 Hz bandwidth minimum in stand alone. I was told when I bought mine this would be lower in future FW releases. We will see.
200 sweep points maximum.
Hope this helps, mark
Lou W7HV 2023/03/24 05:17
I'm far from an expert on the nanoVNA, but I get 401 data points with DiSlord firmware I installed maybe a year ago, which had numerous other improvements too. IDK what minimum selectable IF means.
IW6BFE 2023/03/24 09:40
Thanks a lot.
