John Clark 2020/08/17 07:27
Thank you Holger for that information.
So if I would like a very high resolution scan I can use Segments= 10,
Data points = 1000, and Scan Average 5,2 ?
John
On 8/17/2020 1:22 AM, Holger Müller wrote:
> Hi John,
> On 17.08.20 02:53, John via groups.io wrote:
>> How does 'Segments',
>> Device Settings values:
>> Validation,
>> Data Points (11-1021),
>> and Bandwidth relate?
> There is no relation between that settings.
> And Bandwidth is still greyed out with V2.
>> How should these be used?"
> As you Like it"
> Datapoints can be increased to get more points in one
> sweep segment and therefore speed up data aquisition.
> They can be decreased to get faster smaller part of
> meassurement and this can even be useful if one
> use exponential segmentation.
>> Also in Device Settings are listed:
>> NanoVNA-V2 v1.01
> That's the firmware on the device
>> Features
>> Customizable data points
> Yes, points per sweep can be modified and aren't fixed
> to 101 or so.
>> S21 hack
> The first S21 measurement point of a sweep is way off
> with current firmware, so that value will be discarded.
>> Multi datapoints
> A single datapoint can be acquired multiple times inside
> of the device. A feature which is currently not used as
> I don't know what the implication of this setting would be.
> Perhaps it's meant to be the same as the bandwidth
> implementation in V1 devices.
> 73
> Holger, DG5DBH
