Upgrading to a 4 inch screen? Adding a battery?
Robert Gast 2020/09/21 16:01
I just got my nano vna2 and it will probably become my most used piece of gear for a while. I'm currently prototyping a coherrent x4 sdr reciever, and I dont like sending of for pcb so I do a lot of home toner transfer and freehand milling on Roger's pcb. This thing will be a lifesaver for microstrip above frequencys my my scope and awg cant do bode plots!
Anyways I'll be looking at it a whole lot and a 4 inch screen would be great, I see some people here have already done that but I'm not real sure what the procedure is or exactly what screen has to be purchased for the upgrade. My pcb is labeled S-A-A v2 if that makes a difference.
Lastly looking through the pdf manual it says that the side LEDs indicate battery life, my vna did not come with a battery, nor do I see any documentation on adding one. I have a bunch of flat lipos from blowing up those cheap ebay transistor testers, but I'm not sure if the vna even has charging capabilities built in or if that's something I'll have to do myself? Googling shows the original nanovna had lipo charging support but there is like no info out there on the nanovna2.
John Gord 2020/09/21 21:46
Robert,
Here is a link to the schematic, it should answer some questions about the battery management (yes, it has charging capability). There should be a 2 pin connector on the board for the battery, or at least holes for such a connector.
https://groups.io/g/NanoVNAV2/files/User%20Manuals,%20How2,%20Examples/Gabriel%20v2_2%20schematic.pdf
On Mon, Sep 21, 2020 at 07:08 PM, Robert Gast wrote:
Siegfried Jackstien 2020/09/22 12:29
And adding 4 inch is easy...
Fire up v2 with left button pressed
Start vnaqt soft and connect to device
Soft will say there seems to be a device in dfu mode... Do you wanna flash fw?
Click yes... Wait a few seconds
Done
Now you can put the 4 inch on
Or you can plug it on before connecting to pc
Does not matter if you change the lcd before or after flashing fw
So... Add a battery... 1000 to 3000mah lipo...
Flash fw for 4 inch
Have fun
Dg9bfc sigi
Ps i also added a 4 inch on my v2
Am 22.09.2020 06:46 schrieb "John Gord via groups.io"
<johngord=verizon.net@groups.io>:
> Robert,
connector.
<https://groups.io/g/NanoVNAV2/files/User%20Manuals,%20How2,%20Examples/Gabriel%20v2_2%20schematic.pdf>
> \--John Gord
Robert Gast 2020/09/22 08:42
Thanks, but I'm still unsure what lcd to buy. Is there any specific LCD module with pin compatability? What is the LCD driver chip being used on the 4inch display?
Siegfried Jackstien 2020/09/22 17:22
https://www.amazon.de/dp/B08F7WGNRB/ref=cm_sw_em_r_mt_dp_5xwnFbC3TYY9A
driver ic st7796s
same can be found on aliexpress
i had to desolder the sd card holder but its not used anyway ...
so more or less direct drop in
Am 22.09.2020 um 15:42 schrieb Robert Gast:
Robert Gast 2020/09/22 10:46
Awesome, thank you!
I had a pretty cool idea though for when I'm using on the bench. I use a
raspi to control all my test gear with SCPI over ethernet. The nanovna
software is in at so I'm assuming its cross platform, I'll just use
vnasaver on the pi so I can get a nice 20 inch view while im at the bench!
I wanted to add the 4 inch screen and make an aluminum case, but i just
read there are some kind of frequency reflections when there are metal
sides placed over the sides? Maybe some near field probes and extra pcb
shielding can solve that?
On Tue, Sep 22, 2020, 10:25 AM Siegfried Jackstien <
David Douard 2020/09/22 13:05
I've recently purchased such an 4" screen on aliexpress ( this one ( https://fr.aliexpress.com/item/4001212025453.html ) ), no pb.
( https://nextcloud.sdfa3.org/s/RQkBsKnJY2W4q2D/download )
I'm about to make a PCB to mount this bigger lcd module properly on the nanovna (just a pair of pin headers and a few holes for the screws).
David
Siegfried Jackstien 2020/09/29 15:24
david
i dropped you a direct mail about your adaptor pcb
nice idea (but i have a few more ... grin)
Am 22.09.2020 um 20:05 schrieb David Douard:
David Bradley 2020/09/29 18:00
Ok Sigi I get it many thanks ,73 Dave stay safe
Siegfried Jackstien 2020/09/29 17:35
and another one ... grin :-)
Am 29.09.2020 um 17:00 schrieb David Bradley:
David Bradley 2020/09/30 22:05
Wow Sigi ur on a roll mate 👍👍
David Douard 2020/10/07 12:38
So I've sent my quick'n'dirty PCB design (along with a more serious one to share the shipment price) with only the LCD connection "shift". As Siegfried mentioned, there is room for improvement, but as I had no time (I wanted my other PCB to be sent, so I ruch this out a bit).
Nonetheless, nowI have a few of them (you know how this works nowdays), so if someone is interested, I can sell some for a few bucks (+shipping).
Here is the result:
I've used 12mm spacers, so the resulting "sandwitch" is pretty thick. It's also the price to pay to keep a pin header connector between the LCD and the breakout board. Soldering a board to board header between these 2 boards would allow to reduce the space between them to a couple of millimeters.
David
