Unable to connect to Windows 10 pc
Rasika Liyanage 2020/07/01 05:44
Hi
I'm unable to see my VNA V2 under device in vna_qt_windows software. I have installed CypressDriver on my Win 10 PC too.
appreciate your help on this please.
cheers, ras
MarkZ 2020/07/01 06:43
First step is to ensure it's connected ok. Start with the vna off/disconnected.
1. Run Device Manager in win10 (right-click start then select it from the popup menu or...)
2. Open the Ports (COM & LPT) 'folder' in device manager and note the list.
3. Plug in the usb cable between the pc and the vna.
4. Turn on the vna.
5. You should see an entry for the vna show up in the Ports folder. Mine just says "USB Serial Port (COM24)". Note the COMnn value for later.
Rasika Liyanage 2020/07/01 23:49
Thank you Mark.Followed the steps and found out when i plugged the VNA through the USB cable it is not showing under device folder.Change the USB cable bingo start papering under device folder (in my case COM8)Now I can see in VNA in QT software.Appreciate your help on this.
Stay safe | Cheers - Ras
On Wednesday, 1 July 2020, 11:43:36 pm AEST, MarkZ <mzachma@gmail.com> wrote:
4. Turn on the vna.
Neon22 2020/07/01 22:09
Yes its so frustrating that so many USB cables only contain the power wires. Can't tell you how many times I've come unstuck over this :( Apparently I have become to old to learn :)
Dom Baines M1KTA 2020/07/02 07:49
Hint. Mark such cables so you don't have problems again. Power only ones are useful too. I am sure we have all done it. I put a short length of red heat shrink tube over the wire, in shrunk it just squeezes over the mini or micro end. 73 Dom M1KTA
On 2 Jul 2020 06:09, Neon22 <mschafer@wireframe.biz> wrote:
Siegfried Jackstien 2020/07/02 09:42
and I bought a few cables where they wrote charge cable ... and it is a
complete 4 wire
in that case i WANTED only 2 wires but a bit thicker conductors ...
bought 4 cables ... and only one of them was 2 wire grmbl grmbl
that was same frustrating but in the other direction
here i have now about a dozen cables flying around ... and only ONE of
the is a 2 wire ... hmpf
that is for the extra power connector on the pluto (for data line i sure
take a 4 wire cable ... grin)
Am 02.07.2020 um 05:09 schrieb Neon22:
