Tell us about your upcoming products
Roger Need 2020/08/07 17:17
I have been reading on EEVblog that you have some new products under development which will be available soon.  Anything you can tell us about the features/specifications and when they will be available.
Roger
OwO 2020/08/07 22:07
I think they are going to introduce a 3D case and battery first, we just got permission from a member of the community to use their 3D printed case design.
V2 Plus will be available in a few weeks and it's a small improvement on sweep speed (200 points/s) and a bit lower noise.
V2 Plus4 (I think that's what it'll be called) is the 4 inch version, I have prototypes of it working well at 400 points/s sweep (highest that the UI plotting code can handle) but another board iteration + production run will take 1-2 months. It will come with a 3D enclosure by default this time.
igor-m 2020/08/07 22:47
> design.
I've got the H4 in plastic enclosure. I can see it picks up EMI through the case in some extent.
Do you plan a metallic enclosures for your upcoming products? Thanks!
OwO 2020/08/08 15:36
There aren't plans currently (we are all busy with design improvements),
but the 3.2 inch clone you can find on banggood seems to be ok.
