TDR COLORS #nanovna-saver
Phil, WF3W 2022/06/13 19:45
Good day, all,
Can someone, please, tell me what the *GREEN* trace and the BLACK trace represent on the TDR graph. WHERE on this graph is the length value of coax being measured?
Does anyone know why TDR always, severely, bungles the length value of my coax-under-test, e.g., a 54 foot length is given as 1.77 meters.?
Thanks to all 1st responders.
73 - if apropoe
Phil, *WF3W*
John Gord 2022/06/14 00:16
Phil,
Though more recent firmware may vary, take a look at the following message to get some idea on how to set up for TDR:
https://groups.io/g/nanovna-users/message/12494
The time (and length) range depends on how high the frequency range is set.  For long cables, use a lower maximum frequency.
You want a time range that goes up to 200ns or so to allow for the round trip time for a signal on a 54 foot cable; try a maximum frequency of 100MHz or so.
On Mon, Jun 13, 2022 at 10:32 PM, Phil, WF3W wrote:
Siegfried Jackstien 2022/06/14 21:54
how did you set up vf?? (velocity factor)??
as far as i know the value is to be set in "percent" .. means a cable
with vf=0.66 neds a setting of 66
Am 14.06.2022 um 04:45 schrieb Phil, WF3W:
