Stable FW version 20211227 does not work at all with NanoVNA V2 Plus4 Pro hardware!
attilio.panniello 2022/04/01 05:21
Hi all,
Here is my problem: i am trying to measure a 2.4 GHz antenna to validate the quality of NanoVNA V2 Plus4 Pro hardware and it seems not to work at all with FW  20211227 (stable)
Measurement setup:
Calibration Port1 : 2GHz to 3GHz
This is the result I get....definetely not working!
If Ithen flash FW 20220301 ( experimental ( https://nanorfe.com/downloads/20220301/nanovna-v2-20220301-v2plus45.bin ) ) version, it looks good (see below), but in this case, nanovna-saver ver 3.10 is not working.
Could someone help?
In both FW case, the use of vna_qt_windows is really painful and not user-friendly!
The GUI of Libre VNA looks a way better, could this be maybe inspiring?
Best Regards,
Attilio.
attilio.panniello 2022/04/01 05:55
Hi All,
Can someone on your side test if FW version 20211227 is working on NanoVNA V2 *Plus4 Pro* hardware ?
On my side, it works only if I flash version FW 20220301 ( experimental ( https://nanorfe.com/downloads/20220301/nanovna-v2-20220301-v2plus45.bin ) )...
But then I am not able to see my VNA with Nanovna-saver version 3.10....
Generally speaking, the GUI software experience is not really great unfortunately....any chance that you could got inspired by LibreVNA GUI interface? ;O)
Best Regards.
Shadow 2022/04/01 11:59
Version: 20211227 working well on NanoVNA V2Plus4, post your set up and all steps for comparing...
