Shack W PC Com port Saver problems #nanovna-saver #nanovna-saver
John 2020/10/03 11:13
I have moved my S-AA V2 down to the shack.
I installed CypressDriver and did a system restart.
I connected SAA and turned on and Device Manager reports a new "USB to UART Adapter"
with the Cypress driver, Location "Port_#0001.Hub_#005"
But no new COM port shows.
I always have COM1 physical port I use with K2
I have virtual pairs 7-17, 8-18, and inverse.
but nothing came up when SAA activated.
VNA-QT only lists Com1 and Saver shows no COM ports.
When I read the Events | Information of the SUB to UART Cypress driver Properties
I see "Device USB\VID_04B4&PID_0008\DEMO requires further installation".
I then select "View all Events" I am taken to Windows Event Viewer
Showing "Driver Management has concluded the process to add Service CypressSerial for Device Instance ID USB\VID_04B4&PID_0008\DEMO with the following status: 0.".
I am at Wits End!
John
TI4JWC
John 2020/10/03 11:36
FOUND the FIX!
When the USB adapter was started Windows was building an "Unknown device" in the Device Manager list. I did not see this the first 5 times
I turned on SAA. When I selected this Unknown device and updated driver.
Cypress was installed and now
ALL IS WELL.
Now to install the update firmware.
John
