Set the sweep points
Josh A 2020/11/02 21:52
Is there any way to set the sweep points on the device on the V2 plus 4? I
can't see it in the menu.
Josh
amirb 2020/11/02 04:00
can somebody point me to a modified firmware for SAA-2N (V2) that let us ti have more sweep points?
I think there is such mod for nanovna-f or -h4 but is there any for SAA-2N?
thanks
OwO 2020/11/02 20:37
STIMULUS > CFG SWEEP > SWEEP POINTS
It is still limited to 201 points max in all firmware builds. There is
not enough ram for 301 points on V2_2 and V2_3. On V2Plus4 there is more
free ram and supporting 301 points is possible with some more
optimization work.
Josh A 2020/11/03 06:48
Thankyou. I am enjoying using the v2 plus 4 very much.
On Mon, 2 Nov 2020 at 10:37 pm, OwO <OwOwOwOwO123@outlook.com> wrote:
Alexander Kalashniko 2020/12/14 16:10
Hello, all.
I have removed several unneeded functions, and cleaned debugging a bit and was able to compile firmware with 241 points on my v2_2.
Thank you.
C.M. 2020/12/14 19:47
Here is a trial firmware which can set sweep points to 301:
https://groups.io/g/NanoVNAV2/message/1776
