SV-4401A VNA
Bernie 2022/11/12 16:23
Hello Group:
I have been reading all the posts and comments about the NANO VNA and the clone problems.  I did try the NANO VNA V2 PLUS4 but the 4 inch screen
did my old eyes in and that is why I'm leaning toward the SV-4401A with the 7 inch screen and the "N" connectors.  Does anyone have first hand knowledge
they would like to share about this product.  The You Tube video does discuss operation but only as an instruction.  I would like comments from a actual
users prospective. As example, is it a V2 PLUS4 in a new box or is it an older design in a new box ?
You can reach me here or on the email shown on QRZ for Bernie/W4EDX.  Thank you again.
Vladimir Lebedev 2022/11/13 02:58
Hallo Bernie!
Link http://www.sysjoint.com/en ( http://www.sysjoint.com/en )
Best regards
Vladimir. dl7pga
David J Taylor 2022/11/13 14:34
On 13/11/2022 00:23, Bernie wrote:
> Hello Group:
> again.
I bought one of these, but sent it back. The (UK) supplier didn't even refund
my full payment, claiming missing parts and a broken scree - as if I would have
sent it back in that condition!
- various things didn't work, like something as basic as setting the clock.
- the firmware/software appeared to be a year or more behind that for other
devices. Many missing functions.
- it's very big and bulky.
- it actually has SMA connectors (which I would prefer) but it had adapters
inside from SMA to the external N. So for my use it meant SMA-N-N-SMA. What a
mess!
I was disappointed as the large screen also appealed to me, but I'm £100 short
now, so I can't find a lot to say in its favour. If it worked I might have
kept it.
David
W0LEV 2022/11/13 17:21
Pretty pricey! .......
On Sun, Nov 13, 2022 at 10:50 AM Bernie <BGW210@currently.com> wrote:
> Hello Group:
> knowledge
> actual
> Thank you again.
Roger DL2YDP 2022/11/14 03:14
I have a Nano VNA plus 4 and a SV-4401A VNA. I have compared both devices and will keep both devices!
I mostly use the SV-4401A VNA in the shack and the Nano-VNA plus 4 outside for antenna construction or when I'm on the go.
The ease of use speaks clearly for the SV-4401A VNA and there is also current firmware 0.2.4
Bernie 2022/11/14 06:39
I now have something to think about before purchase.  Yes it is pricey but I could justify that if it was fully operational (maybe).  David has
some user info that also helps, seems they have some clean-up to do along with some Quality issues.  Being in Reliability and QA for many
years I can appreciate those inputs.  And Roger is a user without any issues.  Thank you to everyone for their inputs.  I believe I will wait
a bit longer before I make the purchase and see if others users have any input.
Thank you again and 73's. Bernie/W4EDX
Danny K5CG 2022/11/15 09:13
The only thing that would make me buy this device would be higher dynamic range than my NanoVNA V2. Then I could use it for other things the V2 can't handle. But alas, about the same.
Scott, Christopher 2023/01/22 07:45
I recently bought a 4401 and love it.  It may have some software quirks, but none have been a problem so far. The 7 inch screen is a game changer - much easier to see and use the menus.  It is powered by two internal (replaceable) 18650 batts. And it has N connectors, so no SMA 500 cycle lifetime limitations.  For S11 measurements, it shows pretty much the same results as my HP 8714ES.  I think that it will soon capture the low end of the VNA market.  The next rung up is probably the Siglent.  Beyond that is serious money.
