Anyone bought one of these SA6 spectrum analysers?
I was trying to find the software and drivers that are compatible with it.
>From reading the technical description and the spec, please be aware of the following:
The RBW is fixed at 200kHz which means its is either very slow over a large frequency range or it will only sample certain frequencies while possibly missing in between signals and and it can not resolve any two or more signals within 200kHz.
Its using RF to DC mixing so it can have many subharmonics for any signal that enters the mixer appearing as unexpected spurs.
The dynamic range is only 75dB
Using the internal attenuator can add a lot of level inaccuracy (up to +/- 8dB)
There is no specification of the spur free dynamic range so you do not know if you are able to measure harmonic in a reliable way.
Thanks for this information!
Hank
On Fri, Aug 12, 2022 at 12:03 AM Erik Kaashoek <erik@kaashoek.com> wrote:
