Request for source of the SOLT calibration method equations
nanov2support 2023/12/18 22:37
Hi, the SOL calibration code example can be found here:
https://gist.github.com/nanovna/af6d7c93221a5673451e6f6e64f210e7#file-read_points-py-L212
You may apply a normalization for thru for SOLT calibration.
shlomi.bouscher 2023/12/19 01:00
Thank you both for the information! I indeed came across this code.
Regarding the thru (S21) measurement I'm a bit confused: Indeed for some frequencies, the normalized S21 parameter is >0dB, indicating the need for calibration.
Why can I just normalize the curve to a maximum of 0dB? Are there no frequency-dependent calibration effects at all? (or are they negligible?)
Best!
Jim Lux 2023/12/19 20:50
Typically the calibration would make the S21, with just the cables, be 0 dB, flat. The raw measurement won't necessarily be flat (the detector gain varies, the source level varies, the loss in the cables varies).
shlomi.bouscher 2023/12/19 22:36
Thank you very much for the help! I now have a properly working Matlab code for the NanoVNA V2 Plus4. After some field testing I think I'll upload it to the Matlab Exchange.
Best,
Shlomi
nanov2support 2023/12/19 23:23
> negligible?)
The thru normalization is to be done per frequency, so each frequency point is separately normalized, which takes care of frequency dependent effects.
W4JDY1953_G 2025/12/27 10:00
Let me know where in MATLAB you U/L it or email it to me …
What a great idea !!!
