Reflection Loss from VNA Doesn’t Match Free-Space Transmission Equation – Need Help Debugging
Saud Aldhafyan 2025/08/10 23:33
Hello everyone,
I’m trying to calculate the *reflection loss (RL)* from complex permittivity and permeability values measured at *8.2 GHz* , but my result from the *free-space transmission line equation* doesn’t match the RL measured directly by the VNA.
*VNA Measured Data (at 8.2 GHz)*
freq (Hz) e′ e″ μ′ μ″ S11 (LogM) S21 (LogM) 8.20E+09 2.62 -3.84E-2 0.774 5.06E-2 -7.80 dB -0.897 dB
*My MATLAB Code:*
clc; clear;
% Constants
f = 8.2e9; % Hz
c = 3e8; % m/s
Z0 = 377; % Ohms
d = 0.00215; % m
% Material properties
epsilon_real = 2.62;
epsilon_imag = -3.84E-02;
mu_real = 0.774;
mu_imag = 5.06E-02;
% Complex values
epsilon_r = complex(epsilon_real, -epsilon_imag);
mu_r = complex(mu_real, -mu_imag);
% Input impedance
term1 = sqrt(mu_r / epsilon_r);
term2 = tanh(1j * 2 * pi * f * d / c * sqrt(mu_r * epsilon_r));
Zin = Z0 * term1 * term2;
% Reflection loss
RL = 20 * log10(abs((Zin - Z0) / (Zin + Z0)));
disp(RL);
*Problem:*
VNA measured RL (S11 in LogM) = *-7.80 dB*
My calculated RL = (different value, not matching)
*Question:*
Am I using the correct formula for free-space reflection loss?
Is there an error in my use of tanh or impedance formula?
Could this be because the permittivity/permeability values I have are already extracted from S-parameters, making this calculation redundant or incorrect?
Is there a more accurate way to compute RL from ε′, ε″, μ′, μ″ for a finite thickness sample?
Any help with identifying what I’m doing wrong (or missing) would be appreciated.
gary miller 2025/08/11 11:48
tanh is the hyperbolic tangent function. I believe the tan function should be
used.
I would also recommend testing your code on a half wavelength slab (reflection
should be zero) and a quarter wavelength slab ( reflection should be high)
> On Aug 11, 2025, at 09:30, Saud Aldhafyan via groups.io
<Aldhafyans=gmail.com@groups.io> wrote:
> Hello everyone,
> I’m trying to calculate the **reflection loss (RL)** from complex
permittivity and permeability values measured at **8.2 GHz** , but my result
from the **free-space transmission line equation** doesn’t match the RL
> **VNA Measured Data (at 8.2 GHz)**
> freq (Hz) | e′ | e″ | μ′ | μ″ | S11 (LogM) | S21 (LogM)
> 8.20E+09 | 2.62 | -3.84E-2 | 0.774 | 5.06E-2 | -7.80 dB | -0.897 dB
> **My MATLAB Code:**
> clc; clear;
> % Constants
> f = 8.2e9; % Hz
> c = 3e8; % m/s
> Z0 = 377; % Ohms
> d = 0.00215; % m
> mu_real = 0.774;
> mu_imag = 5.06E-02;
> % Complex values
> % Input impedance
> % Reflection loss
> disp(RL);
> **Problem:**
> * VNA measured RL (S11 in LogM) = **-7.80 dB**
> * My calculated RL = (different value, not matching)
> **Question:**
> * Am I using the correct formula for free-space reflection loss?
> * Is there an error in my use of `tanh` or impedance formula?
> * Could this be because the permittivity/permeability values I have are
incorrect?
> * Is there a more accurate way to compute RL from ε′, ε″, μ′, μ″ for a
appreciated.
W0LEV 2025/08/12 17:35
This may be totally "all the wall", but: Your VNA measurement is in a
50-ohm system. Your calculations are in a free space impedance, 120π ohms.
On Tue, Aug 12, 2025 at 4:59 AM gary miller via groups.io <gary_e_miller=
> be used.
> (reflection should be zero) and a quarter wavelength slab ( reflection
> should be high)
> On Aug 11, 2025, at 09:30, Saud Aldhafyan via groups.io <Aldhafyans=
> Hello everyone,
> permittivity and permeability values measured at *8.2 GHz*, but my result
> *My MATLAB Code:*
> clc; clear;
> % Constants
> f = 8.2e9; % Hz
> c = 3e8; % m/s
> Z0 = 377; % Ohms
> d = 0.00215; % m
> mu_real = 0.774;
> mu_imag = 5.06E-02;
> % Complex values
> % Input impedance
> % Reflection loss
> disp(RL);
> *Problem:*
> *Question:*
> incorrect?
> appreciated.
Jim (WB6FMA) 2025/08/12 11:14
Saud
It’s the finite thickness of the sample.  You have to sum multiple reflections from each side of the sample, or the sample has to be thick enough that there is enough loss that they are negligible.  In real world there are errors from reflections from clutter behind the sample and from how you launch into the sample too (directional antenna, waveguide flange et cetera).  The incident wave isn’t an idealized plane wave.  It’s easier if the sample properties are very different from free space and if one way loss is significant because it makes the errors less significant.  If mu is very close to free space you will have a hard time measuring it.
Jim
Saud Aldhafyan 2025/08/15 14:06
I adjusted the code to include the complex propagation constant for a
wave in the material. Since the signal travels slower in the medium than in
free space, I set the effective speed to 1.67×10⁸ m/s. The results were
almost the same.
On Wed, Aug 13, 2025 at 11:31 AM Jim (WB6FMA) via groups.io <spamsigns=
gary miller 2025/08/16 11:14
I used the attached reference textbook and built a simple spreadsheet and
calculated a return loss close to what you measured.
![image0.jpeg](cid:mf_27F24ED5-C055-4AB2-AEA1-38231E12FCA3/L0/001)![image1.jpeg](cid:mf_C5056577-A69C-464C-8D13-E3E1628E97F8/L0/001)![image2.jpeg](cid:mf_0D4E51A6-A9B9-42FB-
BE82-BE6CA50A9751/L0/001)
> On Aug 15, 2025, at 12:01, Saud Aldhafyan via groups.io
> I adjusted the code to include the complex propagation constant for a wave
in the material. Since the signal travels slower in the medium than in free
space, I set the effective speed to 1.67×10⁸ m/s. The results were almost the
same.
[groups.io](http://groups.io)
<spamsigns=[gmail.com@groups.io](mailto:gmail.com@groups.io)> wrote:
>> Saud
>> Jim
JRW 2025/08/16 20:53
Looking at your spread sheet:
1. f = 8.2 GHz therefor  lambda = 0.03656m
so, the phase constant beta = 2pi/lambda or 2pi/0.03656 = 171.86
In the spread sheet beta = 7.34E+10 ... How did you arrive at this number ?
Jeremy
On 16/08/2025 18:14, gary miller via groups.io wrote:
Donald S Brant Jr 2025/08/17 05:28
Man, Ramo, Whinnery and Van Duzer sure brings back memories!  I still have my copy somewhere.
73, Don N2VGU
Bob Novas 2025/08/18 14:34
![image0.jpeg](cid:mf_88B7FC33-684C-4BAF-81F4-05AA27AB50D2/L0/001)
> On Aug 18, 2025, at 14:30, Donald S Brant Jr via groups.io
my copy somewhere.
> 73, Don N2VGU
gary miller 2025/08/19 15:56
You are correct. I forgot to divide by c. The result for the reflection coefficient is about -9.5 dB.
On Monday, August 18, 2025 at 11:30:00 AM PDT, JRW via groups.io <wallerjr=bigpond.com@groups.io> wrote:
Jeremy
I used the attached reference textbook and built a simple spreadsheet and calculated a return loss close to what you measured.
On Aug 15, 2025, at 12:01, Saud Aldhafyan via groups.io <Aldhafyans=gmail.com@groups.io> wrote:
   I adjusted the code to include the complex propagation constant for a wave in the material. Since the signal travels slower in the medium than in free space, I set the effective speed to 1.67×10⁸ m/s. The results were almost the same.
On Wed, Aug 13, 2025 at 11:31 AM Jim (WB6FMA) via groups.io <spamsigns=gmail.com@groups.io> wrote:
Saud   It’s the finite thickness of the sample.  You have to sum multiple reflections from each side of the sample, or the sample has to be thick enough that there is enough loss that they are negligible.  In real world there are errors from reflections from clutter behind the sample and from how you launch into the sample too (directional antenna, waveguide flange et cetera).  The incident wave isn’t an idealized plane wave.  It’s easier if the sample properties are very different from free space and if one way loss is significant because it makes the errors less significant.  If mu is very close to free space you will have a hard time measuring it.   Jim
gary miller 2025/08/19 13:24
I wore out my first one and am using the second.
> On Aug 19, 2025, at 10:59, Bob Novas via groups.io
<bob.novas=verizon.net@groups.io> wrote:
> <image0.jpeg>
my copy somewhere.
>> 73, Don N2VGU
Jim (WB6FMA) 2025/08/20 17:38
Staying off topic.  A salute to Professors Whinnery, Van Duzer and Angelakos who taught me from that book at UC when I was fortunate to be there.—Jim
