Has anyone tried to measure the input impedance of any SDR Dongle using a
Nano VNA?
Regards.
Nano VNA?
Regards.
i would never try that ... 10mw into the antenna socket will kill your sdr
Am 03.07.2021 um 20:24 schrieb Esteban H:
> dg9bfc sigi
perhaps not - there's protection diodes on the front of the RTL-SDR and
the R820T input chip might tolerate +10dBm no damage
https://www.rtl-sdr.com/wp-content/uploads/2013/04/R820T_datasheet-Non_R-20111130_unlocked1.pdf
doesn't give a max, but
https://www.onesdr.com/2020/01/29/how-not-to-break-your-software-defined-radio-hardware/
gives the following table (without saying where they got the numbers)
*HackRF <https://amzn.to/3ccMZ2e>* – 5 dBm 0.3 milliwatt
*RTL-SDR <https://amzn.to/3ies9mz>* +10 dBm 10 milliwatt
*ADALM Pluto <https://amzn.to/3yQLmke>* +2.5 dBm 1.8 milliwatt
BladeRF +2.5 dBm 1.8 milliwatt
*SDRplay RSP1A <https://amzn.to/3pqMPcZ>* 0 dBm 1 milliwatt
ok .. the rtl dongle may be safe ... but others not
maybe you can measure them when you add an attenuator in line (and
calibrate WITH attenuator)
how accurate that will be?? no idea ...
what does the input impedance tell you??
for me on sdrs most needed values are ... sensitivity and dynamic range
... but not the input impedance
if you want to add filters in line ... and filter responce does change
with receivers impedance ... ok then it will play a role
Am 04.07.2021 um 19:22 schrieb Jim Lux:
When you put an attenuator on the input of the SDR, tmho you will not
measure ihe input impedance of the SDR, but of the attenuator, more or
less.
Jos
Op 4-7-2021 om 19:43 schreef Siegfried Jackstien:
> range ... but not the input impedance
> greetz sigi dg9bfc
>>> your sdr
>>> dg9bfc sigi
>> and the R820T input chip might tolerate +10dBm no damage
Dit e-mailbericht is gecontroleerd op virussen met Avast antivirussoftware.
https://www.avast.com/antivirus
if you calibrate the vna WITH attenuator it should be calculated out
(more or less) ... not?!?
it is "nearly" the same as when you measure with a vna over a longer
cable (that also has loss plus shifts the phase and reverts impedance
every quarterwave)
calibrating should take care of that
Am 04.07.2021 um 20:17 schrieb Jos Stevens:
Here is a section of the AirSpy R2 specifications. Note the max input RF
is +10 dBm (10 mW):
The NANOs can be set for less than 0 dBm output which certainly will not
damage the input preamp. HOWEVER, that level will likely put the input
stage into saturation where a faithful measurement of the input Z will not
be possible. When measuring preamps I usually stick to something less than
-45 dBm (-20 dBm from the TG and 25 dB attenuator) to be sure I'm not
driving the amp into non-linear regions where measurements do not reflect
normal operation.
On Sun, Jul 4, 2021 at 6:17 PM Jos Stevens <jrs@xs4all.nl> wrote:
> Hi,
> less.
> Jos
> > greetz sigi dg9bfc
> >>> your sdr
> >>> dg9bfc sigi
When you calibrate WITH the attenuator you calculate out the attenuation
, but you are no more measuring the imput impedance of the connected
device, am I wrong ?
Jos
Op 4-7-2021 om 20:26 schreef Siegfried Jackstien:
> every quarterwave)
> dg9bfc sigi
>> Hi,
>> or less.
>> Jos
>>> change with receivers impedance ... ok then it will play a role
>>> greetz sigi dg9bfc
>>>>> your sdr
>>>>> dg9bfc sigi
Ok, but an attenuator could be used then. I will calculate in my case the
needed attenuation.
Thanks.
El dom., 4 jul. 2021 18:06, Siegfried Jackstien <
siegfried.jackstien@freenet.de> escribió:
Jos,
Doing the "open, short, load" calibration at the attenuator output allows the VNA to do the math to figure out the unknown impedance connected at that point. The cost is in dynamic range: The test signal is attenuated both on the way out and on the way back in. Adding a 10dB attenuator increases the noise of the measurement by something like 20dB.
On Sun, Jul 4, 2021 at 12:00 PM, Jos Stevens wrote:
Interesting point. Thus, attenuation cannot be arbitrary high, it can be
selected to do not damage SDR at the same time we keep in the dynamic range
of the NVNA for a coherent measurement.
Thanks.
El dom., 4 jul. 2021 21:34, John Gord via groups.io <johngord=
verizon.net@groups.io> escribió:
The HackRF is very vulnerable, but the data given in the article at onesdr is incorrect. The most common damage is to the LNA, which has a damage level of 13dBm. Other paths are less vulnerable. I designed a protected version with effective limiting diodes, and none of those is units (over 1000 so far) has been reported to have been damaged, compared more than one in ten of the original type.
Hi John,
I never have thought that the VNA calculated back the impedance at the
end of the attenuator, when I measure an RF amplifier of eg 20dB, I
always put an attenuator of at least 20dB's in front, I'm afraid the
accuracy of the impedance measurement will be poor then.
Thanks for your reply,
Jos
Op 4-7-2021 om 22:33 schreef John Gord via groups.io:
> Jos,
> --John Gord
> attenuation
> Jos
> calculated out
> longer
> impedance
> every quarterwave)
> dg9bfc sigi
> Hi,
> you will not
> attenuator, more
> or less.
> Jos
> in line (and
> and dynamic
> responce does
> play a role
> greetz sigi dg9bfc
> your sdr
> dg9bfc sigi
> damage
> <https://www.rtl-sdr.com/wp-content/uploads/2013/04/R820T_datasheet-Non_R-20111130_unlocked1.pdf>
> <https://www.onesdr.com/2020/01/29/how-not-to-break-your-software-defined-radio-hardware/>
> <https://amzn.to/3ccMZ2e>>* – 5 dBm 0.3 milliwatt
> <https://amzn.to/3ies9mz>>* +10 dBm 10 milliwatt
> <https://amzn.to/3yQLmke>>* +2.5 dBm 1.8 milliwatt
> <https://amzn.to/3pqMPcZ>>* 0 dBm 1 milliwatt
> antivirussoftware.
> https://www.avast.com/antivirus <https://www.avast.com/antivirus>
