Plus4 Pro DOA
rimantas.balciunas+n 2023/06/21 15:21
Hi all,
I just received my Plus4 Pro in the mail.  I'm excited to put it to use.  When I plug it in and turn it on, however, all I get is a rapidly flickering screen, like a strobe light.  There doesn't seem to be any obvious damage to the VNA or the box that it came in.  Is it possible that this is a known issue that I can troubleshoot?
Rimantas
nanov2support 2023/06/21 21:40
Hi, this usually means it's not getting enough current from the USB port, can you try plugging it into a USB charger or power bank?
rimantas.balciunas+n 2023/06/21 21:53
It turns out that it was the USB cable's fault.  I wasn't initially using the cable that came with the unit because it was too short, and the one I used instead must have been low quality.  Using the original cable fixed the issue.
Thanks for the help!
Mark Libner 2023/06/22 06:25
Or put a charged battery into it.
