PC SOFTWARE
David Eckhardt 2020/12/02 21:20
I can access the following URL which is supposed to contain the download
for QT:
https://github.com/nanovna/NanoVNA-QT/releases
That takes me to:
https://nanorfe.com/nanovna-v2.html
Which, when I click on software (for PC), it takes me right back to the
first URL. Where do I download the PC SW to operate theV2's?
Even the original NANOVNA-SAVER does not operate the V2's, but has no
problem with the originals.
Ken Sejkora 2020/12/02 16:44
Hi Dave,
Give this link a try:
https://github.com/nanovna/NanoVNA-QT/releases?spm=a2g0o.detail.1000023.4.78404e30lrBZz6
73 -- Ken, WB0OCV
Sent: Wednesday, December 2, 2020 04:21 PM
To: nanovnav2@groups.io
Subject: [nanovnav2] PC SOFTWARE
I can access the following URL which is supposed to contain the download for QT:
Ken Sejkora 2020/12/02 16:48
Be sure to scroll downward about one screen where the downloads for various platforms are listed. Latest version appears to be 07-May-2020.
Sent: Wednesday, December 2, 2020 04:44 PM
To: NanoVNAV2@groups.io; David Eckhardt
Subject: RE: [nanovnav2] PC SOFTWARE
Hi Dave,
73  --  Ken, WB0OCV
Reinier Gerritsen 2020/12/02 23:00
download the zip file from github and unzip to whatever place you want
on you pc. The executable file is vna_qt.exe, it can be found in the
release folder.
Op 2-12-2020 om 22:20 schreef David Eckhardt:
Siegfried Jackstien 2020/12/02 22:43
https://github.com/nanovna/NanoVNA-QT/releases/download/20200507/vna_qt_windows.zip
.... qt works fine with v2 or v2plus or v2plus4
https://github.com/NanoVNA-Saver/nanovna-saver/suites/1433144064/artifacts/24188230
32 bit
https://github.com/NanoVNA-Saver/nanovna-saver/suites/1433144064/artifacts/24188229
64 bit
.................... nano saver 38 works fine with v2 v2plus v2plus4
https://groups.io/g/nanovna-beta-test/files/NanoVNA-App.rar
and this nanovna_app also works with v2 v2plus (and can be used with
plus4 with some tricks)
so ... THREE software that work with v2 v2plus v2plus2
Am 02.12.2020 um 21:20 schrieb David Eckhardt:
David Eckhardt 2020/12/03 22:04
Thank all of you who sent me links. I now have an executable QT to run the
V2's. However, I can not connect. I have also installed the USB driver
which is suggested on the site. COM1 somes up, but no connection. I've
also tried COM4 with no luck. If the V2's should work on the 3.8 rev of
SAVER, my V2's do not connect to that either. Yes, the USB cables I'm
using are good.
Suggestions??
> *From: *Ken Sejkora <kjsejkora@comcast.net>
> *Sent: *Wednesday, December 2, 2020 04:44 PM
> *To: *NanoVNAV2@groups.io; David Eckhardt <davearea51a@gmail.com>
> *Subject: *RE: [nanovnav2] PC SOFTWARE
> Hi Dave,
> 73 -- Ken, WB0OCV
> *From: *David Eckhardt <davearea51a@gmail.com>
> *Sent: *Wednesday, December 2, 2020 04:21 PM
> *To: *nanovnav2@groups.io
> *Subject: *[nanovnav2] PC SOFTWARE
> for QT:
David Eckhardt 2020/12/03 23:17
Oh, yes,and I should mention that while connected to the PC, when I switch
on the V2, I a get the expected audible report that the USB port has become
active, so USB is recognized, but can not connect to the NANOVNA - SAA-2 in
either QT or rev 3.8 of SAVER. All work properly as stand-alones.
On Thu, Dec 3, 2020 at 10:04 PM David Eckhardt via groups.io <davearea51a=
> the V2's. However, I can not connect. I have also installed the USB
> driver which is suggested on the site. COM1 somes up, but no connection.
> I've also tried COM4 with no luck. If the V2's should work on the 3.8 rev
> of SAVER, my V2's do not connect to that either. Yes, the USB cables I'm
> using are good.
> Suggestions??
> Dave - WØLEV
>> Hi Dave,
>> 73 -- Ken, WB0OCV
>> for QT:
> *Dave - WØLEV*
Siegfried Jackstien 2020/12/03 23:45
you have to switch the device on before fire up saver or qt (only then
windows will give the software the right comport number)
here the comport number is com 32 ... but it can be near any number ...
check what comport is new (it sure is not com1!!)
before connecting to saver you should check that you have avg set to
"none" (no avg) and save that in slot 0
otherwise saver will show a fault and will not work (say you have set
avg to x5 and soft asks for 100 points but gets only 20 points back)
ALL THREE SOFT WORK WITH V2 ... VNA_QT ... VNA_SAVER ... NANOVNA_APP ...
if you still have problems just ask
Am 03.12.2020 um 23:17 schrieb David Eckhardt:
Hans-Joachim Pietsch 2020/12/04 21:54
Mein NanoVNA V2 arbeitet mit beiden Programmen
David Eckhardt <davearea51a@gmail.com> schrieb am Mi. 2. Dez. 2020 um 22:21:
