Forgive my ignorance, please, but what it the red cap for that is included with the test bugs. Thanks!
dust cyap to protect the ports if not used?!?
Am 26.03.2022 um 11:09 schrieb Anthony:
Way to big for that. I've concluded that there is no real purpose and
that it was put on there to make people ask questions. LOL. If it was to
keep debris out, why no protection on the open and short? See, another
question.
Chuck
On 3/26/2022 8:15 AM, Siegfried Jackstien wrote:
On Sat, 26 Mar 2022 03:09:31 -0700
It's to protect the cal standards against dust and grit ingress, really
you should put one on each standard but the load is probably most
susceptible to contamination, the open least and the short can simply
be blown clear of any dust if you don't have a cap.
The cal process is fairly resilient at the frequencies this VNA can
reach, it gets much more difficult when you get to 13GHz or so and
higher because the wavelengths are so much smaller and a mis-seated
connector can produce significant phase errors.
Brian Morrison
"I am not young enough to know everything"
Oscar Wilde
Thank you for the explanation Brian. This would explain why they only
provide 1 cap and it was on the load.
Anthony (N2KI)
On Sat, Mar 26, 2022 at 10:12 AM Brian Morrison <bdm@fenrir.org.uk> wrote:
