No output power control on NanoVNA V2 Plus5
j.a.e.rosenberg 2024/04/01 05:23
I just got this device and it works great. I just cannot set the output power.
I am getting -7.5dBm (at 12MHz) regardless of the output power setting.
I get -11.5dBm at 2GHz, also regardless of the output power setting.
Does anyone have a solution?
Best regards,
Hans Rosenberg
Rob Rowlands NZ6J 2024/04/01 11:06
Hi Hans,
I have this NanoVNA too. It’s disappointing that the power is fixed. Im
measuring. -9dBm at 12MHz, regardless of the power levels 0-3 under “ADF 4350
TX Power”.
![image0.jpeg](cid:EEE105F9-1365-45AC-A6F8-BE0C743D0816-L0-001)
The manual I’m using just says it’s for special cases, without elaboration.
Best regards,
Rob Rowlands
415 849 5667
power.
> Best regards,
> Hans Rosenberg
Jim Lux 2024/04/02 06:42
The drive changes are more about harmonic content, I suspect - and optimizing
the drive to the mixer LO ports.
> On Apr 1, 2024, at 9:59 PM, Rob Rowlands NZ6J <rowlands47@gmail.com> wrote:
> Hi Hans,
TX Power”.
> Best regards,
> Rob Rowlands
> 415 849 5667
power.
> Best regards,
>> Hans Rosenberg
