Newbie /home/lawrence/Downloads/NanoVNA/NanoVNA_QT_GUI-x86_64.AppImage
lawrenceragan 2020/09/10 09:50
Qt installed and comes up (shotcut) with message: failed to open/home/lawrence/Downloads/NanoVNA/NanoVNA_QT_GUI-x86_64.AppImage
In "help/about' This program uses Qt version 5.14.2.
Open Qt "help/about" This program uses Qt version 5.9.5.
Is this difference the issue? I simply downloaded NanoVNA/NanoVNA_QT_GUI-x86_64.AppImage and click on it.  running from a terminal, I get: NanoVNA_QT_GUI-x86_64.AppImage: command not found
Thanks in advance for you advice
Aaron - WY1P 2021/04/03 14:29
If I am understanding the issue correctly, right click the file and check permissions. I had to check a box to enable it to be executable.
