New User
Dale Drake 2021/01/20 15:04
Just got a NanoVNA V2 from Tindle.  Now I just need to learn how to use it.  I have never used a VNA before.  I'm interested learning how to use it for common mode coax chokes.
Dale AA1QD
Siegfried Jackstien 2021/01/21 05:32
Look in youtube.
. A lot if good videos can be found there..
Greetz sigi dg9bfc
Am 21.01.2021 00:04 schrieb Dale Drake <daleaa1qd@gmail.com>:
> Dale AA1QD
Reinier Gerritsen 2021/01/21 18:18
> Dale AA1QD
Excellent choice, the V2. I would start experimenting with basic stuff
to get used to to VNA measurements and see the effects of resistors,
capacitors and inductors, cables, antennas, hand effect on antennas. The
most important thing to learn is to  get a feeling of trust of the
measurement. A VNA will always show something, but if you make a mistake
in calibration or have a imperfect RF adapter, you must be able to sense
that. If you think you know the basics, try 1 GHz and see how 1 mm
longer wire will change the results.
Second most import, learn how to interpret the Smith chart. Way more
important than swr.
Enjoy your journey!
Reinier
barnc4br 2021/01/21 12:49
b4 you start experimenting with DUTs, I would suggest learning HOW to use it. At least, that is what I had to do. While I did that I wrote a MISSING MANUAL. Though it is specifically for a V2.4, it may help. It is in the files section. Feel free to correct it or add specifics for your V2. If you send them to me I will update it.
