Nanovna2 sma broken
iw4ehj 2024/03/20 03:31
Good morning, I purchased a Nanovna2 some time ago, now an angular SMA connector has broken. Is it possible to know if there are spare parts and how to find them so that I can replace it. Thank you.
Dragan Milivojevic 2024/03/20 19:04
You are asking where to buy a common RF connector?
On Wed, 20 Mar 2024 at 16:30, <iw4ehj@alice.it> wrote:
Bob W0EG 2024/03/20 14:36
Try adafruit.com
On Wed, Mar 20, 2024 at 11:30 AM <iw4ehj@alice.it> wrote:
stevenmclark1 2024/03/20 23:06
Hi!
I'm in the U.S. so I can't see the Aliexpress for Italy, but this link ( https://www.aliexpress.us/item/3256804843806184.html?spm=a2g0n.productlist.0.0.19bc392aBUURe9&browser_id=31e6c9efce584f069669e5a562814341&aff_platform=msite&m_page_id=iaihdqtmicauoqyj18e5f6c8b1714849bc61ba0d86&gclid=&pdp_npi=4%40dis%21USD%211.42%210.99%21%21%211.42%210.99%21%402101e5f117109979328045498e5e7c%2112000031390698270%21sea%21US%210%21AB&algo_pvid=973e9afb-2c78-41a6-b389-5ff440d37eff ) has a promising connector.
I see two at it.farnell.com, one by Johnson-Cinch Connectivity (Part Number 142-0701-501) and another by Amphenol RF (Part Number 132203).
It will take some care and patience to remove the broken one from the PCB without damaging the PCB. It looks like it will require flux, and some solder wick (braid), etc.
Hope this is helpful! Please let me know if there are any questions or concerns!
Good luck!!
- Steve
F4WCV 2024/03/21 01:47
No worries they are easy to change. Best to cut off the old pins then remove the bits with. Soldering iron and resolder a new one.
One tip is always cover your sma sockets with the red rubber caps when not in use. If you are clumsy like me and drop your vna chances are the sma sockets, even if slightly are no good anymore. The treads are very fragile and you will find you have a hard time screwing a cable on again.
cocopuppy 2024/03/21 14:49
Another thing to do is get good quality M-F SMA “jack savers” and mount them on the SMA connectors. This way, if the threads get buggered up, you just change the jack saver, and you are back in business. It doesn’t help with snapping them off, but I think that is not as much a big deal than cross threaded or other wide “screwed up” threads
Frank
KA2FWC
Siegfried Jackstien 2024/03/21 22:43
heat the ground side and centre and peel it off the board (pull sideways)
easy with hot air.. not so easy but doable with a bigger soldering iron
Am 21.03.2024 07:06 schrieb stevenmclark1@gmail.com:
> Hi!
> I'm in the U.S. so I can't see the Aliexpress for Italy, but [this
link](https://www.aliexpress.us/item/3256804843806184.html?spm=a2g0n.productlist.0.0.19bc392aBUURe9&browser_id=31e6c9efce584f069669e5a562814341&aff_platform=msite&m_page_id=iaihdqtmicauoqyj18e5f6c8b1714849bc61ba0d86&gclid=&pdp_npi=4%40dis%21USD%211.42%210.99%21%21%211.42%210.99%21%402101e5f117109979328045498e5e7c%2112000031390698270%21sea%21US%210%21AB&algo_pvid=973e9afb-2c78-41a6-b389-5ff440d37eff)
wick (braid), etc.
concerns!
> Good luck!!
> \- Steve
stevenmclark1 2024/03/22 08:08
The M-F SMA "jack-savers" look like the image below-
These are particularly useful because SMA connectors have a limited number of mating cycles ( ~600) and if these are used on both ports they can just be replaced when the contact becomes suspect. This means the jack on the PCB does *not* have to be replaced because it has only had, for example, the one mating cycle when the "jack saver" was put in place.
The image is of a part from Amphenol SV Microwave Part Number SF2997-6003 listing on DigiKey... Less expensive parts are available from Aliexpress, etc.
I just wanted to be sure it was clear what the discussion was about... Sorry if this seems pedantic.
Again, good luck with all your projects!
Best,
Steve
