Nanovna v2 plus 4 main board schematic
Arturo LU6ETB 2024/02/26 14:36
Hi
Where can I find the Nanovna v2 plus 4 main board schematic?
raspberry4GB 2024/02/27 08:57
Clones and proprietary are the only two words that come to mind when this question is asked...
Then again there is reverse engineering but good luck with that!
Dave 2024/02/28 17:46
I doubt that the designers would release thatthey already have enuf
problems with people creating clones
cheers
Dave
----- Original Message -----
NanoVNAV2@groups.io
To:
<NanoVNAV2@groups.io>
Cc:
Sent:
Mon, 26 Feb 2024 14:36:06 -0800
Subject:
[nanovnav2] Nanovna v2 plus 4 main board schematic
Hi
Email sent using Optus Webmail
Links:
[1] https://groups.io/g/NanoVNAV2/message/4630
[2]
mailto:NanoVNAV2@groups.io?subject=Re:%20%5Bnanovnav2%5D%20Nanovna%20v2%20plus%204%20main%20board%20schematic
[3]
mailto:lu6etb@gmail.com?subject=Private:%20Re:%20%5Bnanovnav2%5D%20Nanovna%20v2%20plus%204%20main%20board%20schematic
[4] https://groups.io/mt/104598293/86894
[5] https://groups.io/g/NanoVNAV2/post
[6] https://groups.io/g/NanoVNAV2/editsub/86894
[7] mailto:NanoVNAV2+owner@groups.io
[8]
https://groups.io/g/NanoVNAV2/leave/12470687/86894/1292362870/xyzzy
cocopuppy 2024/02/28 08:45
Someone posted the for a USB C charging problem
A real usb-c charger needs a 5.1kohm pull-down resistor to start providing 5v VBUS https://electronics.stackexchange.com/a/314188/172286
These resistors have been added between version 3.1 and 3.3.
3.0 schematics https://github.com/hugen79/NanoVNA-H/blob/0fea2293aaf15a76923ec121635489e6c9526613/doc/Schematic_nanovna_Sheet-1_20190711140429.jpg
3.3 schematics https://github.com/hugen79/NanoVNA-H/blob/bf6e64393a983fad2cf1f8a339cdd19b1fbac433/doc/Schematic_nanovna-H_Sheet-1_2019092.png
android 2024/02/28 13:46
There is a link to the github repository on their website
https://nanorfe.com/nanovna-v2.html#schematics
The schematic software used appears to be gEDA (which I gave up trying to install on Linux because it seems to be an old program with a lot of dependancies on old stuff yada yada) but they also have a PNG image of the schematic in github which matches the V2 Plus4 board I have. I wish they would migrate the project to Kicad.
nanov2support 2024/02/28 21:02
Hi, you can find schematics for the V2_2 version on our website at nanorfe.com. We do not have public schematics for newer hardware versions like the V2 Plus4.
Arturo LU6ETB 2024/02/29 07:40
Thanks for answering my question.
My problem is that the U861 burned and the board is destroyed.
I was able to get an MXD8641 to replace it, but I need to rebuild the connections on the board.
The truth is that I don't know if I'll be able to do it but I have to try.
Could you share the details of the connections with me?
Do you have any advice for repair?
Please see attached a photo of the board.
Thanks in advance
Greetings,
Arturo
cocopuppy 2024/02/29 12:48
Is it the can traces that got screwed up , or the IC wires>
Reinier Gerritsen 2024/02/29 19:03
The easy way is to clean the pads with solder wick (add flux) and flux
remover. Then put a tiny bit of low temperature solder paste (bismuth -
tin) on the pads (e.g. with a tooth pick) and use a heat gun to reflow
it. No worries about shorts if you use just a little bit of paste. It
also has good self aligning properties. You'll need much more heat when
using lead-tin or (almost) pure tin solder paste.
If you don't have solder paste, just make sure there is a tiny little
bit of solder on each pad and add a few drop of flux. Then reflow with
the heat gun.
There are a ton of youtube videos how to replace smd parts. I've
succesfully revived 4 units. And add an ultra low capacitance esd diode
at the input to protect the switch. (Search the forum, I've posted the
part number several times).
Succes, Reinier
Op 29-2-2024 om 16:40 schreef Arturo LU6ETB:
Arturo LU6ETB 2024/03/01 23:10
The mxd681 caught fire and the prints were ruined.
I hope it's just the IC connection traces.
My idea is to clean the board well, glue the IC and solder the legs of the IC.
In order to do this, I need to know where to connect the pins of the IC.
That's why I was looking for the motherboard diagram.
If the diagram is not available, I would appreciate at least the connections of IC U861
Greetings,
Arturo
android 2024/03/02 16:59
Hi Arturo
See the attached pic of my Nano VNA V2 Plus4 board. As far as I can tell, the U801 chip is wired the same as in the V2_2 png schematic.
Good luck - although I suspect other damage was done to your board too.
Cheers
Andrew
Arturo LU6ETB 2024/03/03 09:58
Hi Andrew,
Thanks a lot for the picture.
Greetings
Arturo
Arturo LU6ETB 2024/03/07 22:59
I have the main board picture (Thanks Andrew) and the MXD8641 IC.
Now, the issue is how to solder it and reconstruct the traces. I found the MXD8641 is a QFN-14L 2mm×2mm×0.55mm package.
Then, I think I will not be able to do the repair.
On one side
I reached Tindie store and they said that they don't sale spare parts and suggested to contact factory.
Feb 23rd, I sent and email info AT nanorfe.com, CC edelswartz123 at gmail.com requesting the spare and there was no answer.
On the other side
I found an adapter at https://www.proto-advantage.com/store/product_info.php?products_id=3100127
What do you think about this adapter?
Has anyone tried it?
Thanks & Regards,
Arturo
