Nanovna V2 plus5
glpragma 2022/02/10 07:24
Hello everyone,
I'd like to be sure before buying, any of you could be so kind to proper explain me the specs differences between nanovna v2 plus4 and its sibling model nanovna v2 plus5?
Thank you guys.
D.
OwO 2022/02/11 05:10
New in V2 Plus5 (renamed to V2 Plus4 Pro):
- Adjustable bandwidth; possibility of measuring very narrowband devices.
- Maximum sweep speed increased to 600 points/s; speed increases below 140MHz.
- Slightly improved noise compared to V2 Plus4.
V2 Plus4 already has the lowest noise out of all NanoVNAs, so V2 Plus4 Pro is only a small improvement there. See: https://nanorfe.com/nanovna-v2.html#clones
Francesco 2022/02/11 10:55
You change the the FW for the v2Plus4?
**Sent:** Friday, February 11, 2022 at 5:10 AM
**To:** "NanoVNAV2@groups.io" <NanoVNAV2@groups.io>
**Subject:** Re: [nanovnav2] Nanovna V2 plus5
New in V2 Plus5:
\- Adjustable bandwidth; possibility of measuring very narrowband devices.
\- Maximum sweep speed increased to 600 points/s; speed increases below
140MHz.
\- Slightly improved noise compared to V2 Plus4.
V2 Plus4 already has the lowest noise out of all NanoVNAs, so V2 Plus5 is only
a small improvement there. See: <https://nanorfe.com/nanovna-v2.html#clones>
Bill 2022/02/12 18:03
I'm considering a purchase as well and am wondering how much difference these additional 200 points in the sweep would add. I'd be using this mostly for general ham band antennas. Not too much in the GB range.
WA2TP 2022/02/13 04:32
I’m curious if the hardware is actually the same and this isn’t something easily accomplished with a simple firmware upgrade. Won’t take much to order one from Amazon, open it up to see and then return it once we know.
Seems a bit sketchy that it appears identical.
Michael Brun 2022/02/13 07:01
Not sure the minor improvements justify an additional purchase when one already owns the V2+4.  Will be keeping an eye out for substantial performance improvements and/or feature additions.
Dave Johnson 2022/02/13 10:06
Yeah, and I think that sentiment is pretty ubiquitous because they now changed the product name to V2plus4Pro 🙄
VNA2 2022/02/13 19:00
I an SAA-V2 I use for ham radio.  It works great.  I use it at the antenna, then in the shack.  After an antenna build/install and TX line is run into the shack, I run it via laptop using 500 points.  That 500 is probably overkill.  My background is all around transmitters.  HF to 8 Ghz, backed up with expensive equipment purchased for use at federal facilities.  1st class FCC at age 19. Retired from FAA in 2017.  If you use a manual antenna match, the nano VNA works well to tune without sending any RF that may interfere.
Bill 2022/02/14 15:41
I was just reviewing the Specifications table again (https://nanorfe.com/nanovna-v2.html#specifications) and wanted to clarify something.
I would be using this mostly for HF antennas, 3.5MHz~50MHz. If I am reading the specifications table correctly, I would only be seeing 200 points on the screen of the V2 Plus4 for the HF range, but with the V2 Plus4 Pro I would see 600 points even in the HF range? That seems to be a significant difference. Is my understanding correct?
Reinier Gerritsen 2022/02/15 09:16
No, this is incorrect. It is the measurement speed 200 vs 600 points per
second. Both will give sufficient real-time measurement experience.
Op 15-2-2022 om 00:41 schreef Bill:
zeljko adzic 2022/02/15 10:52
this is not quite truly
On Tue, 15 Feb 2022, 09:16 Reinier Gerritsen, <r.gerritsen@idcircuits.com>
WA2TP 2022/02/15 10:57
However, if you use the 2plus4 with a pc, you will be able to measure over 2000 points.
On Tue, 15 Feb 2022, 09:16 Reinier Gerritsen, <r.gerritsen@idcircuits.com<mailto:r.gerritsen@idcircuits.com>> wrote:
