NanoVNA V2 / Forum
To post, join https://groups.io/g/NanoVNAV2
Nanovna Brick
Lars Harms 2020/06/27 07:19
Hello everyone,
i am not sure about which firmware to use with my Nanovna saa2. I tried to
upgrade it via Dfu, but now it is a brick.
Using the ST Link V2 ends in a download error. The device is found by the
programmer and he is trying to download the file but at the end there is a
segment 0 error. I used the version from the link, which points to the
latest release.
Where can i find the V2.2 file for the device ? This was the version,which
was originally on the device. But i was unable to use the nanovna saver
software.
At the moment i am little bit confused, this is not my first Stm 32 i want
to program...
Best regards
Lars
OwO 2020/06/27 17:43
DFU upload should be safe, it's not possible to overwrite the bootloader
by DFU upload. If the upload fails you can just retry it.
If you use SWD to flash the firmware, it must be flashed to address
0x08004000. You will need to reflash the bootloader at 0x08000000. You
can find the bootloader binary.bin here:
https://github.com/nanovna/NanoVNA-V2-firmware/tree/master/bootloader
On 27/06/2020 13:19, Lars Harms wrote:
Siegfried Jackstien 2020/06/27 10:10
i also had no luck with nanovna saver but vna-qt works fine
and that is also what i used for upgrading ...
press left button and switch on (while connected to pc)
fire up vna-qt and select the device (the correct comport)
it will ask if you wanna update firmware
press yes
select file
easy as baking cakes
https://github.com/nanovna/NanoVNA-V2-firmware/releases/tag/20200619
if you have a normal (small) display then take the ili9341 version
and here you find the pc software
https://github.com/nanovna/NanoVNA-QT/releases
take the vna-qt-windows zip ... unzip in a folder on your pc
done
Am 27.06.2020 um 05:19 schrieb Lars Harms:
Lars Harms 2020/06/27 12:20
Thanks alot. Pointing me to the Bootloader, which i messed up was the right hint. Flashed it and afterwards flashed the Firmware with the nanovna QT.
No more brick, only fun with my new toy.
Great work guys.
Gesendet von Mail ( https://go.microsoft.com/fwlink/?LinkId=550986 ) für Windows 10
*Von:* Siegfried Jackstien ( siegfried.jackstien@freenet.de )
*Gesendet:* Samstag, 27. Juni 2020 12:13
*An:* NanoVNAV2@groups.io
*Betreff:* Re: [NanoVNAV2] Nanovna Brick
press yes
select file
done
> Hello everyone,
> latest release.
> software.
> to program...
> Best regards
> Lars
Siegfried Jackstien 2020/06/27 10:47
THUMBS UP ..
HURRAY IT WORKS :-)
Am 27.06.2020 um 10:20 schrieb Lars Harms:
