NanoVNA v2 frequency resolution
Kevin Zheng 2024/10/23 15:47
Dear NanoVNA v2 users,
I'm looking to buy a NanoVNA v2 for our lab. While looking at the
NanoVNA v2 specifications
(https://nanorfe.com/nanovna-v2-user-manual.html#specifications) I was a
bit confused by the "Frequency resolution" parameter, which is given as:
Frequency resolution: 0.01MHz
What exactly is this frequency resolution? Does it mean that the minimum
distance between two points on a frequency sweep is 10 kHz?
In other words, on the low end of 50 kHz, does this mean that the best
the NanoVNA can do in a frequency sweep are 50 kHz, 60 kHz, 70 kHz...
and so on?
If so, does anyone happen to know where this limitation comes from? e.g.
is there a signal source that's only programmable in 10 kHz increments?
Kevin
Kevin Zheng
Ph.D. Candidate, Electrical Engineering and Computer Sciences
University of California, Berkeley
nanov2support 2024/10/23 22:31
Hi, yes that is correct, this is due to the divisor of the fractional PLL being set to 10kHz, limited by the ADF435x maximum fractional denominator.
John Gord 2024/10/24 00:22
Kevin,
There are firmware versions that allow better frequency resolution at lower frequencies, presumably by running the synthesizer chip in a different mode.
My NanoVNA V2 using the Ojisan firmware of Oct 4, 2020 has frequency steps of 3kHz at 1.5GHz, 0.5kHz at 100MHz, and 10Hz or less at 50kHz.
The DiSlord firmware may also offer improved step size at lower frequencies.
On Wed, Oct 23, 2024 at 10:29 PM, Kevin Zheng wrote:
Kevin Zheng 2024/10/24 08:50
Thanks all for the responses.
On 10/23/24 10:22 PM, John Gord via groups.io wrote:
> Kevin,
> different mode.
That helps. Would it be convenient for you to check what frequency step
you can achieve at 20 MHz?
Nonetheless, 500 Hz resolution below 100 MHz is much closer to what
we're looking for.
Kevin
Kevin Zheng
John Gord 2024/10/25 15:24
Kevin,
This is all on the original NanoVNA V2 also known as SAA-2.  I don't have any of the later versions.
At 20MHz, the Ojisan firmware gives 10 Hz step size.
At 20MHz, The DiSlord firmware v1.3.21 gives 1Hz step size.
On Thu, Oct 24, 2024 at 09:59 PM, Kevin Zheng wrote:
nanov2support 2024/10/25 22:08
Hi, the firmware versions *20220814* and later for V2 Plus4/VNA6000 incorporates the changes for improved SI5351 frequency resolution, which I recall is 1Hz, but I will check with engineering.
Please note that all of this only applies below 140MHz, as higher frequencies are covered by ADF435x which has the aforementioned 10kHz limitation.
You can find the latest firmware here:
https://nanorfe.com/nanovna-versions.html#versions
