NanoVNA V2_2 for audio range impedance measurement?
stevenkruyswijk 2025/04/05 03:24
Hi all,
Excuse me if this is a naive question with a highly obvious 'no' answer, but to make sure:
Is it possible at all to get even an estimate of DUT impedance in (part of) the audio range of 20Hz - 20kHz?
Thanks in advance, Steven
W0LEV 2025/04/06 15:44
This subject was addressed several months ago. You might check the
archives. Of course, the answer is "NO".
On Sun, Apr 6, 2025 at 8:01 AM stevenkruyswijk via groups.io
<stevenkruyswijk=gmail.com@groups.io> wrote:
> Hi all,
> but to make sure:
cocopuppy 2025/04/06 12:32
Probably not possible. Audio impedance is a lot higher than 50 ohms. I was thinking of up and down converting, but you would still need to transform the impedances and then calibrate it
An audio analyzer is probably you best bet
Frank
KA2FWC
David Bradley 2025/04/06 18:13
Well I must say this post has had a reply I've posted 3 times and not had
any replies
On Sun, 6 Apr 2025, 16:59 W0LEV via groups.io, <davearea51a=
stevenkruyswijk 2025/04/06 23:14
Thanks - I did do a search for 'audio' but couldn't find any useful results.
