NanoVNA V2Plus 4 Advice please - device failure?
RandMental 2023/01/26 05:31
Good day
I have not used my original V2Plus4 device for a while and updated to the lastest firmware.
It now does not calibrate correctly,  does not remember the calibration and above about 140MHz,  it displays only noise - even if the Port 1 is terminated with 50 Ohm
Please see the photos attached for the screens
Any ideas please - it is the V2Plus4 version before the display change
David J Taylor 2023/01/27 08:22
On 26/01/2023 13:31, RandMental wrote:
> Good day
> lastest firmware.
> with 50 Ohm
Try charging the battery?
David
nanov2support 2023/01/27 08:06
Hi, please use "Contact Seller" on the website you ordered from for warranty service. Thanks
RandMental 2023/01/29 23:49
Thanks David, but that was the first thing I did.
Also removed the battery for a few minutes to ensure any RAM settings are deleted.
The unit reacts this way running of the USB port or the internal battery
Michael Brun 2023/01/31 04:27
Have you tried loading the firmware again?
How about loading an older version of the firmware?
I have not experienced this condition, merely thinking of things I would try.
RandMental 2023/01/31 22:56
Will do Thanks
RandMental 2023/02/01 05:32
Thanks Michael, did try the older firmware - same probleme,  I guess it is a HW issue
radio 2023/02/20 05:48
Same error with the MAGIC number...this looks exactly the same as mine aside the serial number....any news? Just noise...after calibrating\!
