NanoVNA-QT still supported?
mce66 2020/10/31 01:51
do you know the status of the development of NanoVNA-QT? I've seen that this very nice tool is not recompiled since may, even if some commits are available. Moreover, no new feature have been implemented (like enhanced response or other possible improvements). It would be a pity since this tool is quite useful.
Siegfried Jackstien 2020/10/31 14:51
i guess most users use nanovna saver and use the qt only for flashing new fw
saver is as useful as vna qt (besides the missing software upload) but
can show 4 (up to 6) values where qt only shows 3 (2 sweeps plus smith)
that may explain why no new features are added
Am 31.10.2020 um 08:51 schrieb mce66:
Peter Ide-Kostic 2020/11/01 08:22
I am a big fan of nanovna-saver but let's be serious it does not really
NanovnaQT.
NanovnaQT has some key feature that nanovna-saver does not unfortunately
offer.
1) The possibility to easily measure and export 4 S parameters (thanks to
the S parameter menu) into an S2P file. Nanovna-saver does not offer the
possibility to generate a fully populated S2P file with the 4 S parameters,
it has to be done manually....
2) It is also runs faster than Nanovna-saver
3)The extended port facility works much better too.
Perer
On Sat, 31 Oct 2020, 15:51 Siegfried Jackstien, <
